Any S2K drivers with aftermarket cat?
2 questions:
A. Assuming you have the factory cat handy, how far apart are the bolt holes on the inlet flange?
B. Where can I get the factory style inlet flange? I'm planning some custom work and I'd like a factory fit using factory bolts, etc.
Any info would be greatly appreciated. Thanks in advance....
No no. I've got a JDM header for my B16 and it uses the S2K donut gasket. I could probably bolt an S2K cat on but the angles are all wrong so I'd like to weld that style flange on a Carsound cat. Guess I should've clarifed that.
