Need advice on new tires ...
Old Jan 1, 2003 | 09:02 PM
SH LUDE's Avatar
Default Need advice on new tires ...
What's up guys,
Just had a quick question. What size tires are people running on there stock SI rims ....I was thinkin' on getting the Falken ZE-512 ZIEX 205/50HR15. Suggestions? Comments? I'm lookin' to spend about 200 dollars also ...the cheapest I found was 222 shipped for those tires. Later guys, TIA
Old Jan 1, 2003 | 09:05 PM
Prelude_2_NV's Avatar
Default Re: Need advice on new tires ... (95 Prelude SI)
i'm running falken azenis sports on my stock si's and they're pretty good
not that great in the wet, especially when u live in a rainy city like vancouver
excellent dry traction though
Old Jan 1, 2003 | 09:08 PM
Lude Vtec 94's Avatar
Default Re: Need advice on new tires ... (Prelude_2_NV)
im running the parada spec 2 there grip decent when its wet out, good traction on dry pavment
Old Jan 1, 2003 | 10:37 PM
SH LUDE's Avatar
Default Re: Need advice on new tires ... (Lude Vtec 94)
Is 205/50/15 too big though? I want the widest tire I can get w/o having the tires make noises and rub against the wheel barrel when I make turns. My car has not been slammed yet either, so keep that in mind please. Thanks again
Old Jan 2, 2003 | 06:05 AM
illusion's Avatar
if SIs use the same rims as VTEC, which i think they do, then 205 is fine. our wheels are 6.5" width.
Old Jan 2, 2003 | 07:13 AM
aklucsarits's Avatar
New User
Stock tire size is 205/55/15 IIRC. 205/50/15 is slightly smaller in diameter. So you will get an effectively shorter final drive ratio which will aid acceleration. But your speedometer (and odometer) will be reading 3.4% too high.
There is no comparison between the Falken Ziexs and the Falken Azenis. I've owned both. The Ziexs are an All-season tire deigned for good treadwear. If you only care about tire life and maybe drive in the snow a few times a year, these are for you. You might get 40,000mi out of the Ziexs. As a dry weather performance tire, they are mediocre at best. The Falken Azenis, on the other hand, cost a bit more than the Ziexs in 205/50/15, but they are an all-out ultra high performance summer tire. The Azenis are very sticky with a soft compound and stiff carcass. You might get 15,000mi out of Azenis.
Andrew
Old Jan 2, 2003 | 05:45 PM
LudemanDan's Avatar
Default Re: Need advice on new tires ... (aklucsarits)
Yes, stick with 205/55/15. You don't want to be at 4,500 rpm when you're cruising on the freeway. (Okay, that was an exaggeration).
I got the Yokohama YK 420's. They're for all season, but they handle great for what they are. Very nice control. Quiet too. Cheap too, but not quite as cheap as you're aiming for.
Falken Azenis are wonderful if you want a super performancy, great handling tire. But they don't last, and they get loud, and they're still more than you want to pay. And I'm not sure what diameter the 15" one is.
'Fraid you're gonna have to shell out more than you were planning, bro.
Dan
Old Jan 2, 2003 | 08:29 PM
SH LUDE's Avatar
Default Re: Need advice on new tires ... (LudemanDan)
If it reads 3.4% higher on the speedometer and tach, that means what exactly? 205/50/15 will burn more gas and do nothing for you as far as acceleration and handling goes??? Thanks again ...this is my first time buying tires.
Old Jan 3, 2003 | 12:00 PM
LudemanDan's Avatar
What is your motivation for wanting to downsize, anyway? Basically, your speedometer reads the speed by how fast the wheels are turning. Smaller tires have to spin faster to achieve a given speed, so the speedometer, which is calibrated for a tire diameter of about 24", will think you're going faster than you actually are. Similarly, the engine will have to rev a little higher to achieve that wheel speed. Meanwhile, your odometer will rack up miles faster than they are actually accumulating.
As far as accelleration and handling, well, your handling will probably improve. Also, your gearing will get shorter. A little bit better punch probably, but you'll have to shift more often and you'll have to wind it up a little farther to go really fast. In other words, yeah, you burn more gas on the freeway.
Do whatever you want, but I'd recommend sticking with 205/55/15.
Dan
Old Jan 3, 2003 | 12:10 PM
satan_srv's Avatar
I have Toyo Proxes T1-S I think they are one of the best tires out there...
<StevieG>
Honda Civic (2001 - 2005)
12
Apr 2, 2007 07:00 PM
The Weather Man
Mar 4, 2006 10:56 PM
tnewhallSi
Dec 19, 2005 07:23 AM
chotchkie
Mar 30, 2004 07:09 AM
RustyDX
Jul 13, 2002 08:15 PM
