HELP: Idle problems/CEL codes for GSR
Old Jan 1, 2003 | 07:27 PM
ajchen's Avatar
Default HELP: Idle problems/CEL codes for GSR
hey all
my car wasnt driven for 2 weeks. i came back to start it up and battery was dead.. so i jumped it. it drove fine for 15 minutes... i parked it and came back an hour later. it drove ok for about 5 min, and then the CEL came on. the idle is rough around 1400rpm when i am in neutral, and the car is very jerky to drive when i shift. anyone know what this is all about?
how do i access the engine codes on my integra, and does anyone have a list of what the CEL codes are?
thanks!
Old Jan 2, 2003 | 05:21 AM
ajchen's Avatar
Default Re: HELP: Idle problems/CEL codes for GSR (ajchen)
no one in this forum knows how to access the CEL codes in an integra?
Old Jan 2, 2003 | 05:37 AM
Rory Breaker's Avatar
I just posted this about 10 minutes ago in a post entitled...
"CHECK ENGINE LIGHT"
There is a little blue plastic pin connector behind your glovebox...pull that out, and with the key on ON, take a paperclip and connect the two pins together. You will see a series of flashes of the CEL. Those flashes correspond to a number.
IE:
1 Long flash, 4 short flashes = Code 14
4 Long flashes, 3 short flashes = Code 43
Go here to see what your code means if you dont have a helms:
http://www.c-speedracing.com/faq/05.php
buster97
Mar 30, 2013 07:01 PM
PAStA MAAAN
20
Jul 8, 2006 01:53 PM
max240
Feb 24, 2004 04:39 PM
