is a cx swap the same as dx swap in 5th gen
Old Jan 1, 2003 | 07:21 PM
rice4life's Avatar
Default is a cx swap the same as dx swap in 5th gen
i'm planning on swaping a b18c into a 94 hatch cx. i swap a 99 b18c1 into a 92 dx before. other than the wires, what would be different in the swap? is the hub and spindle the same? does the gsr axles fit right in? that's the only concern i have.
Old Jan 1, 2003 | 07:31 PM
VTECVillain's Avatar
Default Re: is a cx swap the same as dx swap in 5th gen (rice4life)
Nothing. It will be the same
The hub and spindle are the same and the axles will fit no problem.
Old Jan 1, 2003 | 07:46 PM
rice4life's Avatar
Default Re: is a cx swap the same as dx swap in 5th gen (VTECVillain)
thanks for the info.
Old Jan 2, 2003 | 05:59 AM
1bad-eg's Avatar
I thought you had to swap out the cx hubs to integ, dx or si because the hubs won't accept the integ's axle spine?
Old Jan 2, 2003 | 10:31 AM
Default Re: is a cx swap the same as dx swap in 5th gen (1bad-eg)
No, they have the same amount splines. You have to change them in the 88-91 Civic STD or CRX HF though.
Old Jan 2, 2003 | 01:10 PM
1bad-eg's Avatar
Thanks VTECVillain.
Old Jan 3, 2003 | 02:31 PM
jmm96gsr's Avatar
Thai, you punk ***...I told you its the same BTW, my dx is a '93. hey, send IM me the website for the 11 inch brake swap.
BossFoss
Dec 16, 2013 01:49 PM
vrrodri
Mar 18, 2003 10:54 AM
red civic standard
Feb 11, 2002 10:04 AM
