sohc zc questions
Old Jan 1, 2003 | 12:06 PM
Ef Whore's Avatar
Default sohc zc questions
are these in need of a rebuild like most of the dohc zc's? are the exhaust ports the same as an a6 or different like the dohc zc? cause i want to use my a6 header if I opt for this motor. what are the diffs between a6 and sohc zc? am I better off just rebuilding my a6? Thanx.
Old Jan 1, 2003 | 12:22 PM
Creepshow S60's Avatar
Default Re: sohc zc questions (Ef *****)
sohc zc has slightly more hp and tq than the d16 is what i hear. i have a sohc zc in my car and it doesn't feel any different than a d16 crx. and as far as the rebuild question you had, check the engine for yourself and see if it needs a rebuild. just because the sohc zc came from japan doesn't mean its been beaten to death and sitting in a rain soaked junkyard for the last 10 yrs like a lot of people believe the zc to be. i mean, sure its possible, but my point is that you should check the engine yourself instead of just immediatly rebuilding it.
[Modified by y-49CRX, 1:24 PM 1/1/2003]
Old Jan 1, 2003 | 12:53 PM
altoid's Avatar
Default Re: sohc zc questions (y-49CRX)
my sohc zc feels like its got more power than the d16a6. But my a6 was running off one cylinder when i pulled it. If you plan to do some mods and the a6 is cheaper and not in shitty condition i say just get that...and the zc is the exact same thing as the d16a6 as far as bolting stufff to it, completely interchangable. my sohc zc came with a dual downpipe header also though, so you may wanna use that
[Modified by altoid, 4:55 PM 1/1/2003]
Old Jan 2, 2003 | 05:36 PM
Ef Whore's Avatar
Default Re: sohc zc questions (altoid)
Since my existing d16a6 has 180k+ miles, I want to know if it would be better to rebuild that (friend would for basically nothing), or get a sohc zc and rebuild that since supposedly it is a quicker motor---is the power noticeable?---what gives it the edge---bigger cam?---higher comp. ratio?--Thanx
EsCo_EsCo
11
Jun 5, 2004 12:01 AM
Dwight Schrute
Feb 22, 2004 03:01 PM
hondacivic4g
Aug 22, 2002 05:26 AM
