I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap?
Old Jan 1, 2003 | 08:57 AM
1badITR's Avatar
Default I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap?
I want to make my 94 Prelude S faster. I have heard I could turbo it for about half the cost of an h22 swap. Is that true? How would the F22 do with boost? Reliability, power. Thanks.
Old Jan 1, 2003 | 09:21 AM
slowh23's Avatar
Default Re: I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap? (1badITR)
If I was you, I'd hold off and save a little more money so I could do the H22 swap. It will leave more options open for you as far as modding goes because you'll only get so far with an F22.
you live in yorktown and drive an S? Ive got the champagne Si prelude i dunno if youve seen it. it got hit a week or two ago so theres a dent in the side.
[Modified by slowh23, 6:23 PM 1/1/2003]
Old Jan 1, 2003 | 09:38 AM
1badITR's Avatar
Default Re: I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap? (slowh23)
My Prelude is white with some 18" RH M5's. I want to drop it, paint it and do something to the motor soon. My main car is a 97 ITR, built motor with a JRSC at 11psi and 75 shot NX. Thanks for the help. Maybe I will see you around.
Old Jan 1, 2003 | 10:06 AM
slowh23's Avatar
do you have your stock prelude wheels? im looking for some. you should come out to the dragva dinner tonight
Old Jan 1, 2003 | 10:20 AM
ViZ's Avatar
ViZ
i did the h22 swap, best thing i ever did
Old Jan 1, 2003 | 11:02 AM
BoostedH23a1's Avatar
Default Re: I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap? (ViZ)
swap u can get jdm h22s for 2300
Old Jan 1, 2003 | 11:05 AM
redracersi's Avatar
Yeah go with the H22 swap. YOu are just lucky you have an easy decision between moding the "S" engine or h22 swap. That is a no brainer!!
but
I have been completing for months on whether to do an h22 swap or rebuild my h23 and turbo that bitch up! I have done months of research and the more I do the more I dont know which one I want. H22 or H23 TURBO
Anyways surely go with the H22 swap!
Old Jan 1, 2003 | 12:23 PM
BlueShadow's Avatar
If you do decide to get an H22 do you plan on boosting that? if you plan to turbo no matter what, then you should compare the costs of making the two engines bulletproof.
You could probably find a used F22 block for really cheap and build it up. Find out if a built F22 at XX amount of boost will be good enough for you. Or maybe you can even consider a built and turboed H23.
If you do plan on swapping in an H22 and turboing it keep this in mind: the stock H22 pistons have weak pistons. So you might be better off buying an H22, building it up (sleeves, pistons, rods) then dropping it in. Then at least when you start boosting you're engine will already be ready for it.
Old Jan 1, 2003 | 02:31 PM
DarkJedi's Avatar
Default Re: I need to make my 94 Prelude S faster. Should I turbo it, or do an H22 swap? (BlueShadow)
if u go turbo using stock internals then u should be a bit slower than a jdm h22 in a drag race but in less reliable setup, just go jdm h22 swap in yourself and save money
jayludeh22
Mar 11, 2008 03:02 AM
otsegolectric
Dec 3, 2007 07:22 PM
macfadyen
Sep 23, 2005 07:51 AM
1badITR
Jan 1, 2003 02:19 PM
