will an entire CRX front end bolt onto a civic HB?
Old Dec 31, 2002 | 05:39 PM
d357r0y's Avatar
Default will an entire CRX front end bolt onto a civic HB?
just wondering.. i prefer the CRX front bumper and i know it wont just bolt up.but if i did the entire front end, would it work/and look stock?
thanks
Old Dec 31, 2002 | 05:49 PM
zcivicz's Avatar
Default Re: will an entire CRX front end bolt onto a civic HB? (d357r0y)
i've read somewhere that you need the CRX fenders to go with the CRX front bumper, someone correct me if i'm wrong
Old Dec 31, 2002 | 05:54 PM
d357r0y's Avatar
Default Re: will an entire CRX front end bolt onto a civic HB? (zcivicz)
yes. i think you are correct there.. i was also wondering about the area where the hood meets the bumper. is it a different filler panel or does the bumper take up that spot?
Old Dec 31, 2002 | 10:00 PM
JDM92CX's Avatar
Of course its possible with a lot of bondo and money
Old Jan 1, 2003 | 12:13 AM
brian g's Avatar
Default Re: will an entire CRX front end bolt onto a civic HB? (xJDM88EF9x)
Everything bolts right up as long as you use pieces from the same group of years, 88-89 or 90-91. If you want to change the years, then you will want the headlamps and side markers too.
The only problem is with the front fenders from the CRX. The have a spot just below the where the side molding goes that uses a black plastic piece that matches the black side skirts that come on the CRXes. When i did my front end conversion, I grafted the lower portion of the Civic's fender on to the CRX fender.
brian g
Old Jan 1, 2003 | 08:10 AM
d357r0y's Avatar
Default Re: will an entire CRX front end bolt onto a civic HB? (brian g)
brian g
this is what i thought, i looked at two fenders side by side last night.. a little welding action and a paint job. thanks
onenonly009
Oct 6, 2007 12:49 AM
inh
Sep 7, 2007 09:08 AM
s2kkk
May 25, 2004 07:19 PM
KoRE
Aug 8, 2003 09:32 AM
pelotudo
Aug 15, 2002 09:51 PM
