how do u take off the rear Si triangle badge?
Old Dec 31, 2002 | 02:23 PM
crx_ef8's Avatar
Default how do u take off the rear Si triangle badge?
same as title. the rear plate wher it says Si how do u take it off? on crx
Old Dec 31, 2002 | 02:25 PM
slowman's Avatar
I took way too long
Default Re: how do u take off the rear Si triangle badge? (crx_ef8)
Triangle badge? I dont know of one of those but i just took mine off today, just used a razor blade to start it and then took the rest off by hand. then a little goo gone for the gooey part.
Old Dec 31, 2002 | 02:35 PM
cr-x si's Avatar
Default Re: how do u take off the rear Si triangle badge? (slowmanEF)
He means that plastic triangle that the "si" sticker in on.
I am not sure how it comes off. I have troble keeping mine on it always comes loose. I think you have to get behind it to get it off. They have these plastic button things that stick the body. (kinda like the way your carpet is held down)
Old Dec 31, 2002 | 03:52 PM
Driven's Avatar
If you open your hatch and remove the rear trim, you can see three little "clips" that hold it on...
get a pair of vise grips and clamp down on those clips and pull the panel out.
The chance of you breaking these clips is 10:1. So, order some from hondaautomotiveparts.com... they are $3/ea. There's three of them.
If you REALLY wanna be creative, they actually screw into the panel...you could use the vise grips and try to "unscrew" the clips from the panel.
good luck
Old Dec 31, 2002 | 07:00 PM
CRX-RX's Avatar
Default Re: how do u take off the rear Si triangle badge? (Driven)
I prefer to put a socket on them for removal. You'll have a hard time just "seeing" them though, they're burried behind chassis metal. And getting in there s no easy task, just think; "small japanese hands".
hiwastar
Honda Civic (2006 - 2015)
10
Mar 15, 2008 10:05 PM
downest
12
May 31, 2007 04:12 PM
90jdmcrxdude
Aug 9, 2006 11:05 AM
90jdmcrxdude
Aug 5, 2006 07:04 PM
HankYee
Oct 16, 2005 12:56 PM
