wats the top speed u hitt with your hatch?
I broke 95 in my 93 Stock CX Hatch last night going down a hill... then I felt bad for my motor which is on it's last leg and slowed down...
Scott
Scott
Guest
Posts: n/a
Keep in mind that the speedometer will probably be incorrect...the needle on my car was almost at the 7 o clock position when I pussied out, and I highly doubt I was going over 130mph.
I hit around 120....then the stupid JDM SPEED LIMITER kicked in
Hitting a speed limiter at 120 feels like you hit a brick wall
you just STOP accelerating very abruptly....very very gay...
I once (and never again) took my 2000 Si to where the speedometer (which was prolly incorrect) to 143. My car was all over the road, and it took some time on a downhill shot to do it.
I know, it said hatch. But I thought I might share.
MY del sol in stock form with the d16z6 didabout 132 once. The car pulled nicely to about 125, where I could feel the wind deflection from the poorly aerodynamically designed del shoe .
I wouldnt advise such speeds without a proper place to do them in, you will need a track with good slow down time, awesome tires and brakes, and tight suspension. I did mine on the interstate with stock replacement tires on stock suspension.....oops
I went approximately 145mph (speedo only goes to 130).
It was during a road trip. I had a passanger and a car load of crap.
It had more to give, but I didn't trust the tires.
wouldn't that be really bad for the brakes?????
you just STOP accelerating very abruptly....very very gay...wouldn't that be really bad for the brakes?????
but can relate 2 it !! had a D15B vtec JDM thingy.. with speed limit sucks ***..
first time i thought that my engine had killed it self !! only like 4 hours after the inst !!
