coil overs with tokico blue struts
i have eibach pro-kit with tokico blue struts... i dont like the way the car sits with the eibach springs so i wana get coil overs... my question is can i use coil over(sleeves) with tokico blues?? if so what kind??
[Modified by 1hotintegra, 7:04 PM 12/31/2002]
I just installed some coilovers with tokicko blues on my friends GSR a couple weeks ago. I was never a big fan of coilvers but they fit nicely. Only thing was his coilovers where an ebay brand. So if those fit im sure anything will fit. But if i was you i would stick with springs that will give you a really nice tuck on the tire.
of course coilovers will work with tokico shocks...
im pretty sure it would be a bad business decision to make products that dont work with other suspension parts.
im trading my friend my H&Rs for his ground controles + 50 bucks (both used) he wants his car as low as mine and i want mine to be about .5" lower than stock (i smash my header too much and know i'll do it when i get a 3" dp with my turbo
) and i was going to get new shocks also... With tokico blues and ground controls as high as they go, how low will my car be? I've heard that the smaller size of the shock tower lowers your car significantly...
-Ryan
) and i was going to get new shocks also... With tokico blues and ground controls as high as they go, how low will my car be? I've heard that the smaller size of the shock tower lowers your car significantly...-Ryan
i have tokico blue in my rear and the instruction say they can be dropped 1.5 max with no problems. another friend of mine has 2.25 drop on them and they are not leaking. i was scared to get tokicos in the front since i have a 2.0 drop. i have some AGXs in the front.
well i.ve got skunk2 coilovers on tokico blues and so far everything has been pretty good. i completely blew the stock shocks and had to get new ones. the only problems i.ve had with the skunk2's is my measuring error with the lowering, slightly lower on one side. but that.s easily corrected. i love the stiffness of the skunk2's.
8.4K_SIR
Suspension & Brakes
24
May 18, 2006 08:15 AM
integraautox
Dec 26, 2002 07:17 AM
