A faster accord?
I'd like to make my Accord a little faster right now im saving the majority of my money to get an h22a but that will be awhile from now until then what can i do.....so far i modified my IAT sensor ive added exhaust and i have an air intake....is there anything else i can swap or change...... My accord is a f22b2 non-vtec SOHC four door 94 LX automatic
is there anything else i can do cheaply......
I fully plan on getting a swap....i was just wondering if theres anything small mechanically i can clean, change wires...plugs something...idont know. id like to make it a little more jumpy....if possible.
i fully intend on getting the swap. but thats going to be at least 3-4 months from now or more. I was just hoping there was something i could do that would make the accord alittle bit more jumpy....spark plugs or maybe a parts swap mod? i dont really know.....
Get POWERED BY HONDA stickers.. those might increase your mid-range power.. id say maybe 5-10hp. Its well worth it. And the girls will be swinging on your *****.
You could alway do a 50 shot of N20. would make you faster and you could easily install it on the H22 later.
otherwise thats about it. new plugs will help keep you in top running shape, but don't expect a lot of gains. depending on your mileage, a highflow cat might give you a little bit.
[Modified by jweller, 5:54 PM 12/31/2002]
Work on the suspension and brakes so that way your chassis will be on the same level as the H22 when you get it.
Some weight reduction would not hurt either. You can work on removing all the sound-deadning material under your carpet, replace those heavy stock seats with some stronger-lighter weight Sparcos/Recaros/Kirbys, throw on a CF hood, get a 15lbs Oddesey battery just to start.
In the brake department, I upgraded to Power Slots/Matrix pads with sucess. I would not plan on going with bigger discs if you are planning to run small drag slicks/wheels in the future because the wont fit.
Laterz
[Modified by Ludehrt, 12:01 AM 1/1/2003]
The mod is pretty easy. It's just a transistor that you plug into the sensor. Don't make the mistake that I did and got it off ebay for $15. Boy was I pissed when I found out it was just a 15 cent transistor from Radio Shack.
Dave
Dave
or you can be like me dump mad money into nitrous and still be waiting for the swap. by the way my accord is a stock motor with a couple of mods. believe me at first i thought the nitrous was worth it but i rather be up there with the bigger dogs with the prelude swap.
v4lu3s
Mar 28, 2012 06:20 PM
