Compatibility: CL/TL Type S parts with 98-02 Accord V6
Can the TL/CL Type S throttle body, cylinder head, intake manifold, camshafts, valves, and header fit on the 2001 Accord V6 coupe?
If I make do the overbore engine block, can I use the CL/TL Type S piston too?
Thanks.
Thanks.
Thanks.
Thanks.
i do not know the spec differences between the Cl Type S pistons and the Accord, diameter etc, that extra .2l of displacement has to come from somewhere, i dont know if its from stroke or bore, im sure the specs are easy to find
Does anyone have an idea if the CL/TL 6speed will bolt up to the J30?
Thanks...D
Thanks...D
Gangsta Accord
Jul 8, 2002 06:16 PM
