GSR is misfiring......PLEASE HELP!!!!
Old Dec 31, 2002 | 12:21 AM
Burglar's Avatar
Default GSR is misfiring......PLEASE HELP!!!!
Ok, at first it was codes 72 and 73, which are cyl. 2 and 3 misfiring. I changed my plugs, wires, and distributor. Checked the timing, and it is perfect.
So after I put on the new distributor, now it is only throwing 71 and 73.....no more 72, but now its missing in cyl. 1 and 3. The injectors are good, we checked those. I also put a p28 in to see if the ECU was my problem, but I'm still getting the same codes.......WHAT IS THE DEAL? PLEASE HELP ME!!!!!
Old Dec 31, 2002 | 01:55 AM
Greasemonkey75's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (Burglar)
As weird as it sounds, what type of alt. belt are you running on the car?
Did it start mis-firing after an event of some sort?
Old Dec 31, 2002 | 07:51 AM
94TealGSR's Avatar
How new is the distributor? Have you tried changing the cap/rotor?
Old Dec 31, 2002 | 07:54 AM
Komsomol's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (94TealGSR)
Sounds like an electrical problem to me.
How is your idle?
What rpm do you misfire at?
Do you find that you misfire more often at low or high temps?
What are the conditions like outside when you are misfiring?
Have you farked around with the computer at all under the kick plate?
Do you have an external coil?
Old Dec 31, 2002 | 10:27 AM
Burglar's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (8400RPMS)
The cap and rotor are both new. My idle seems smooth with the exception of the misfiring. It misses at all temps. It starts throwing the code as soon as you start the car up/
Old Dec 31, 2002 | 11:20 AM
Eva01's Avatar
Just to cover the bases here...Did you install the wires from plugs correctly to the distributor?
Old Dec 31, 2002 | 11:36 AM
Burglar's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (Eva01)
haha.........of course........1-3-4-2
Old Dec 31, 2002 | 01:04 PM
Burglar's Avatar
ttt
Old Dec 31, 2002 | 02:05 PM
SIK IN DA HED's Avatar
New User
did you check your internal coil? did you make sure your injectors are not goin bad? bad spark plug wires?
do a compression check.
Old Dec 31, 2002 | 02:16 PM
smkngsr's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (dlplayboy)
double check everything u changed on the car including the coil...I had a misfire once and it was the spark plugs are too far..so gap them according to the spec...try to check ur ignition wires too along with ur caps and rotors..coz sometimes even if they are brand new they can be defective...hope this helps...if u have some fuel pressure regulator...maybe u need to give it more gas...hope this helps
Old Dec 31, 2002 | 06:01 PM
mickey513's Avatar
What kind of plugs and wires did you use? OEM? Or some cheap aftermarket? I once put some aftermarket parts in and the car misfire
Old Jan 1, 2003 | 11:44 AM
Burglar's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (mickey513)
NGK's and oem wires......
EVERYTHING ignition related is brand new.
Old Jan 1, 2003 | 12:55 PM
smkngsr's Avatar
Default Re: GSR is misfiring......PLEASE HELP!!!! (jtrbocrx)
i got a knock sensor for sale for 40..if ur interested...thanks
Old Jan 1, 2003 | 03:02 PM
Burglar's Avatar
what would the knock sensor have to do with anything? it could misfire bc of it?
Old Jan 1, 2003 | 04:11 PM
SuzukaBlueAP2's Avatar
i had a friend that worked at a honda dealer, and he said a lot of people that start modding their cars have this problem. he told me something, that i'm really not sure that i believe. he said to change your thermostat ?!? i dont get why that would have a role in it really, but. i suppose it's worth a shot
Old Jan 1, 2003 | 07:06 PM
JDlvl InTEGRA's Avatar
Not sure buddy but my friend had that same prob on his 2000 Si and it was some cheap gas he put in and always make sure that u a are using 91 Octane. Also do you misfire during idle or when your giving it some gas? If not when its ilde coulde be bad compression.
AlexStroea
12
Apr 30, 2018 05:15 AM
GoSickemRobert
Oct 9, 2011 02:14 PM
CA6VTEC
Apr 17, 2006 07:28 PM
mR. Vash
Sep 8, 2004 10:50 AM
