**I have a huge problom!!!**
Old Dec 30, 2002 | 03:00 PM
cr-x si's Avatar
Default **I have a huge problom!!!**
My passenger side windshield sprayer isn't working. It only dribbles out. The driver side works good though. So i have a half clean windshield.
Old Dec 30, 2002 | 03:10 PM
Stdsnb16's Avatar
Default Re: **I have a huge problom!!!** (cr-x si)
That sucks! Happened to me a while back actually. The sprayer is probably just clogged like mine was. Just replace it and you'll have a clean windshield again.
Stdsnb16
Old Dec 30, 2002 | 03:12 PM
TypRice's Avatar
Is spelling one of them!
[Modified by TypRice, 6:12 PM 12/30/2002]
Old Dec 30, 2002 | 03:13 PM
TypRice's Avatar
you can take it out and clean it...i did with a needle!
Old Dec 30, 2002 | 03:16 PM
neutron91's Avatar
Default Re: **I have a huge problom!!!** (TypRice)
come on go easy on the guy
Old Dec 30, 2002 | 03:20 PM
crxforum's Avatar
There are a few ways that you are able to rectify this problem. The lines to the squirters are sectioned and connected by joints. You can take them out in sections and put some water in there. Take your air compresser (or your mouth) and put the nossle on the end of it and blast some air in there. If the water comes out the other then then that section is fine. Just do the same to the other ones. It might also be that your line got frozen. I dont know where you live but that is a problem with people who live in Canada and places that are cold. Just squeeze(sp?) the line from the tip to tip and break up the dirt in there. You should be ok there.
CRX Forum
deadmonday08
Oct 24, 2010 09:57 AM
som3on3_10
Jan 6, 2008 07:25 PM
lando griffin
Sep 27, 2007 08:36 PM
IntEGNYC
Dec 23, 2002 01:35 PM
johnzm
Oct 30, 2002 12:02 PM
