HELP....motor swap troubles.need assistance ASAP
Old Dec 30, 2002 | 02:47 PM
maxxdout's Avatar
Default HELP....motor swap troubles.need assistance ASAP
heres the deal, in the process of motro swap and cant remove drivers side driveshaft. Need some advice on this one. IT seems to be binded in the junction between the intermediate shaft and the outer shaft. It has moved very little and this is whats holding me back. ANy help or suggestions as to what tools to try would be appriciated. I have tried pry bars, screw drivers, and hammers. If there is a special tool needed tell me and i will get it.
TIA
Old Dec 30, 2002 | 06:50 PM
b19coupe's Avatar
Default Re: HELP....motor swap troubles.need assistance ASAP (maxxdout)
There are three 14mm bolts that hold the intermediate shaft to the block. With these removed, the axle and intermediate shaft should slide right out.
Old Dec 30, 2002 | 07:27 PM
maxxdout's Avatar
Default Re: HELP....motor swap troubles.need assistance ASAP (b19coupe)
much appriciated. After overlooking such a simple detail i was getting all upset. Got it out no problem. Much thanks
Greatness
Jan 15, 2010 05:21 PM
Wayne_Curr
Feb 12, 2006 05:41 PM
Cheeech
20
Dec 22, 2005 05:55 PM
fu*kfaceC1EH2
Jun 19, 2003 02:54 PM
Unknown Member
Feb 24, 2003 12:23 PM
