Is this car running rich? (pics)
Full size pics to show detail. The car was cleaned and waxed before the drive and after the drive, the rear was totally covered with this stuff. Does not look exactly black...more like brown shiney dust.
Car running rich or what?
That's not some byproduct of running rich. Is your bumper black? If not, then that is something else, like pollen or something else not from the kaa.
BTW IntegraGSR23, REAL Race cars have FOUR pedals.
[Modified by Chris N, 4:50 PM 12/30/2002]
my car does this on the whole rear of my car, but its black spots.
i have a reprogrammed ecu, so i believe (and i hope) its because i am running rich
(i hope its not bad piston rings).
most hondas run rich anyways. also have you changed your plugs every 12k like you should, if not that could be the cause of your sut. bad plugs means a lot of unburnt fuel gets spit out the exhaust and back onto your car.
look at the plugs if you want to know how the car is running.
-tony
errrrrrrrrrrrrrrrrrrrrrnt!
-tony
-tony
Uhm, doesnt this happen to all cars. I think its simply dust that collects on the entire surface of the bumper and rear hatch due to static.
please enlighten me if that is wrong. i was under the impression that if a car was running rich, the plugs would be a dark brownish-black color and if the car was running lean, the plugs would be white. i learned this back in go-karts so it might not carry over...
-tony
-tony
actually, its hard to tell its running rich or lean just by pulling the plug out and see. since all the shitty gas and u are running lean at idle. the only way to tell is to use pro A/F meter.
ciscoscivic
Aug 11, 2009 08:39 AM
AZslowcivicEX
32
Sep 28, 2002 05:33 AM
shi - who didn't know pepboys detailed cars
