anyone have greddy turbo on 99+ ludes?
Old Dec 30, 2002 | 09:37 AM
pdiddy's Avatar
Default anyone have greddy turbo on 99+ ludes?
if so, do you experience any noise from downpipe?
Old Dec 30, 2002 | 10:32 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone have greddy turbo on 99+ ludes? (pdiddy)
why does it have to be 99+ Prelude, why can't it be a 97+
Old Dec 30, 2002 | 10:42 AM
pdiddy's Avatar
Default Re: anyone have greddy turbo on 99+ ludes? (Boosted97Lude)
good question, sorry 97+
Old Dec 30, 2002 | 10:47 AM
Boostless97Lude
Guest
Posts: n/a
oh, ok, in that case, i have one, and i don't have any problems with rattle.... although i don't actually have the DP that came with the kit... i had a custom 2.5" pipe made with a flex in it b/c i was worried about it breaking since it doesn't have anything in it to flex
Old Dec 30, 2002 | 10:52 AM
pdiddy's Avatar
what turbo kit do you have?
Old Dec 30, 2002 | 11:10 AM
Boostless97Lude
Guest
Posts: n/a
what kind were you asking about?
Old Dec 30, 2002 | 11:18 AM
pdiddy's Avatar
lol, I got it...couple other questions. The drain plug, did you mount it the way instructed or did you run the oil return line on the other side. Any pics?
Old Dec 30, 2002 | 11:35 AM
Boostless97Lude
Guest
Posts: n/a
i actually used a moroso oil pan, and used a braided line for the oil return... this is from a thread i made a while back about the return line. no pic of the pan at the time though
i didn't like it either, so i went to a local shop that build race cars, and had some things made
i took this:
and had this made:
Old Dec 30, 2002 | 11:39 AM
pdiddy's Avatar
cool, basically reason is. My friend and I installed greddy kit on his 99 base model, and when he drives it, and bov goes off, we hear this loud sound like something is scrapping. We thought its turbo but it only happens when car is driving, it doesn't happen when we hit gas and car is standing still.
Old Dec 30, 2002 | 11:43 AM
Boostless97Lude
Guest
Posts: n/a
what kind of BOV?
Old Dec 30, 2002 | 11:56 AM
pdiddy's Avatar
what kind of BOV?
greddy type S
But I am not sure if its bov or turbo or dp or what! cause the sound is metal like grinding almost and coming from bottom.
Old Dec 30, 2002 | 12:00 PM
Boostless97Lude
Guest
Posts: n/a
hrmm... you got me, i haven't had any problems with mine doing anything like that.... i don't even know what it could be, other than maybe a problem with the BOV
Old Dec 30, 2002 | 12:15 PM
pdiddy's Avatar
thanks, for the bov, did you use T-fitting to connect the actuator and throttlebody to bov?
Old Dec 30, 2002 | 12:36 PM
Boostless97Lude
Guest
Posts: n/a
i just used one t fitting for the vaccum line going to the BOV... i teed off the cruise control
Old Dec 30, 2002 | 12:45 PM
pdiddy's Avatar
cruise control?
Old Dec 30, 2002 | 01:01 PM
Boostless97Lude
Guest
Posts: n/a
yeah, the cruise control uses a vaccuum signal, you tee off of it for the vaccuum signal for the BOV
Old Dec 30, 2002 | 01:02 PM
pdiddy's Avatar
don't you tee the actuator-bov-throttlebody too?
Old Dec 30, 2002 | 01:13 PM
Boostless97Lude
Guest
Posts: n/a
i have no idea what you arew talking about..... all i did was run a vaccum line to the nipple closest to the top of the the BOV itself, the nipple down below i didn't even mess with
Old Dec 30, 2002 | 01:16 PM
pdiddy's Avatar
but you ran the top nipple to what? You ran it to actuator(goldish piece on turbo) right? And then you teed that to throttlebody right?
Old Dec 30, 2002 | 02:08 PM
Boostless97Lude
Guest
Posts: n/a
NO...... the BOV has an independent vaccuum line.... the "goldish peice" on the turbo is the wastegate which controls your boost.... that is probably your whole probelm right there
you need on vacuum line running to the wastegate
and one running to the BOV
Old Dec 30, 2002 | 02:47 PM
pdiddy's Avatar
isn't that same as running one line off throttlebody and then teeing it with both bov and wastegate?
Old Dec 30, 2002 | 03:04 PM
Boostless97Lude
Guest
Posts: n/a
first off... why are you putting a Tee on the throttle body?
and, i have been told it is not a good idea to use the same vacuum signal for the wastegat and BOV
Old Dec 30, 2002 | 03:05 PM
Boostless97Lude
Guest
Posts: n/a
and, i have been told it is not a good idea to use the same vacuum signal for the wastegate and BOV
and unless your buddy is running a boost guage, he should hve enough vacuum lines coming off the manifold without using a T at all
Old Dec 30, 2002 | 03:17 PM
pdiddy's Avatar
ah so just run wastegate and bov on seperate vacume lines off throttlebody? Thanks man!
Old Dec 31, 2002 | 06:06 AM
jbx's Avatar
jbx
Btw, the greddy Turbo Kit supports up to 99 Prelude.
