Putting a b16 head on the gsr?
Old Dec 29, 2002 | 11:11 PM
careawholelot's Avatar
Default Putting a b16 head on the gsr?
There is a good chance that my head is warped, and if it is, then I might need a new head, and I found a good b16 head for cheap, I was just wondering what I will need to buy? Or will all of the b18c stuff swap right over.
Old Dec 29, 2002 | 11:37 PM
flip b18b's Avatar
Default Re: Putting a b16 head on the gsr? (careawholelot)
for the most part everything will swap over but you will need a b16a intake manifold
Old Dec 30, 2002 | 09:57 AM
redman223's Avatar
Default Re: Putting a b16 head on the gsr? (flip b18b)
So the header, distributor, and all that stuff will bolt right up then? How about the head studs, should I buy ARP ones, and if I did are they the same or are the b16 and b18 ones different, just wondering if I should buy them now or wait until I know the problem for sure...
Old Dec 30, 2002 | 12:14 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Putting a b16 head on the gsr? (redman223)
for the head studs the b16 are to short make sure u buy ones for a gsr, but this set up works perfectly fine
Old Dec 30, 2002 | 03:48 PM
Padawan's Avatar
Darth ModerVader
Also keep in mind that a B16 head on your C1 block will result in a lower compression ratio than the C1 head yielded.
sick93sol
Apr 11, 2009 07:18 AM
95civic16
Apr 23, 2008 06:14 AM
pcguy760
Apr 26, 2005 09:40 AM
1.8T_EG
Oct 21, 2002 08:53 AM
Malice
Mar 6, 2002 07:29 PM
