*Problem with car not reving??Need help please
Old Dec 29, 2002 | 07:22 PM
HybridRexy's Avatar
Default *Problem with car not reving??Need help please
I have a 89 Crx with a 2001 b18c1. Im running it obd0 w/ a pr3 ecu. I've had it in thier for months and now all of a sudden after the car is on for like 5 minutes the car wont rev past 5000 or 5100 and the top end is horrible and sometimes the car just revs at one pot even when Im at full throttle and it makes noise but goes slow,.! WTF I dont understand, if someone can help please it would be appreciated, thanks + =
[Modified by HybridRexy, 4:27 AM 12/30/2002]
Old Dec 29, 2002 | 07:38 PM
altoid's Avatar
Default Re: *Problem with car not reving??Need help please (HybridRexy)
any codes on the ecu? Did you replace something recently hows the compression in the cylinders? It could be on the crutch thingy the ecu sets up for when something dealing with the engine is kaput
Old Dec 29, 2002 | 08:30 PM
HybridRexy's Avatar
Default Re: *Problem with car not reving??Need help please (altoid)
the only code it thros is o2 sensor because it is not hooked up, thats all, compession is good and no chaged parts recently
Old Dec 29, 2002 | 09:40 PM
neutron91's Avatar
hmmm... i knew a guy with a 92 prelude that did the same thing... turned out his cat was all screwed up... he replaced it and all was well
dnaDC2
Mar 28, 2013 08:15 AM
sweetlittleride
Aug 25, 2008 05:19 AM
zyntax
Aug 28, 2006 03:02 PM
hatchinprogress
Feb 26, 2006 07:15 PM
