maintanence help: fuel filter & cap/rotor
Old Dec 29, 2002 | 07:15 PM
magic hat #9's Avatar
Default maintanence help: fuel filter & cap/rotor
i was doing a little maintanence as an addendum to my 30k diy service, but i got stuck and i want to make sure i'm doing this right.
cap&rotor: this is a just a simple procedure of removing the plug wires, removing the cap, pulling off the rotor, and replacing everything, right? is there a correct orientation to put in the rotor? i think it shouldn't affect the timing since i do not loosen the distributor. i just want to be sure i don't have to line anything up.
fuel filter: ok, i got so far as to remove the filter from it's retaining bracket and i removed the gasoline hose as shown below, but i could not remove the filter from the gasoline hardline it is attached to underneath. anybody have any tips/tricks to removing it? i tried, but i couldn't get enough leverage in the tight engine bay even with removing the intake hose. also, once the new filter is in place, is there any technique for starting the car with a fresh filter and avoiding fuel starvation?
Old Dec 29, 2002 | 07:39 PM
uNF$@#!'s Avatar
Default Re: maintanence help: fuel filter & cap/rotor (magic hat #9)
fuel filter you will need to undo the bolt on the bottom of the fuel filter also. put your arm into it, as it is not a easy thing to do.
Old Dec 29, 2002 | 07:48 PM
Eric R's Avatar
Rotor and cap will go in only in one position. Just follow the guide.
No problem with fuel starvation in any car. It takes just a lil bit to start, although if you want, you can prime the fuel filter but, not really needed.
Old Dec 29, 2002 | 07:57 PM
sa21199's Avatar
Default Re: maintanence help: fuel filter & cap/rotor (Tweety R)
just double check that you tightened the bolts for the fuel filter. Forgot to do that once Not a big deal just kind of embarassing.
Old Dec 29, 2002 | 08:09 PM
type r 01-1063's Avatar
From what I read...for the fuel filter you need a flare wrench.
Old Dec 29, 2002 | 11:43 PM
DC2ITR's Avatar
Default Re: maintanence help: fuel filter & cap/rotor (type r 01-1063)
Old Dec 29, 2002 | 11:46 PM
JDM CTR '00's Avatar
Default Re: maintanence help: fuel filter & cap/rotor (DC2ITR)
just use your teeth
Old Dec 29, 2002 | 11:48 PM
TypeR 599's Avatar
Default Re: maintanence help: fuel filter & cap/rotor (ChargedSi99)
just use your teeth
ahh doing it the dr vtech way..
Old Dec 30, 2002 | 01:14 AM
uNF$@#!'s Avatar
nonsense. monkey wrenches do the job.
Old Dec 30, 2002 | 06:01 AM
Default Re: maintanence help: fuel filter & cap/rotor (Soup ****)
how often do you guys change the fuel filter and the cap/rotor? i have 34k now and plan to do this job every 30k.
Old Dec 30, 2002 | 02:00 PM
Eva01's Avatar
Helms does not specify a change time for cap and rotor. It just says to inspect at 60K. Not sure on FF though (Helms is at home) but every 30k sounds like a plan to me .
Dont forget to adjust valves and change the MTF at this point if you haven't already.
[Modified by Eva01, 11:01 PM 12/30/2002]
Old Dec 30, 2002 | 03:36 PM
Tommy_Gunns's Avatar
I need to do these maintenance items this year.
Old Dec 30, 2002 | 04:02 PM
markpaco's Avatar
It is easier to remove the lines from the fuel filter with the filter still mounted to the firewall. This gives you more leverage. A flare wrench is highly recommended. A monkey wrench's teeth may gouge the fastener faces.
Old Dec 31, 2002 | 05:42 AM
Eva01's Avatar
Default Re: maintanence help: fuel filter & cap/rotor (markpaco)
Definatly a flare wrench would be best but not entirely necc. I was able to get my FF off w/ a regular wrench. May take some man-handling but nothing a typical gearhead couldn't handle. Oh, I think soupnazi was kidding about the monkey wrench "NO SOUP FOR YOU!!"
redlinez_r_us
Sep 16, 2009 12:02 PM
.RJ
Sep 29, 2007 10:54 AM
STLblackcivic
Mar 26, 2007 03:12 PM
handa
Apr 3, 2005 03:27 PM
Fez
Aug 27, 2002 07:48 AM
