quick question about gear ratios
Old Dec 29, 2002 | 05:38 PM
altoid's Avatar
Default quick question about gear ratios
Im looking at my honda manual here at the gear ratios for the 4wd tranny and it goes SL through Reverse then has one that says reduction ratio, is the reduction ratio the final drive? and how do you figure the ratio is it (# teeth of gear)/(# teeth of final drive) or vise versa thanks
Old Dec 29, 2002 | 07:25 PM
civicwagonman's Avatar
Default Re: quick question about gear ratios (altoid)
I think that is the final drive to the transfer case, since it has a separate ring and pinion gear for that. it gears it down some and then gears it down more in the rear diff. kind of a wierd setup, but it works.
Old Dec 29, 2002 | 07:36 PM
altoid's Avatar
Default Re: quick question about gear ratios (civicwagonman)
yeah i think thats it i was reading through it more throughly and what you said seems about right. thanks
gilou bilou
Nov 10, 2005 02:06 PM
RS_91
Aug 27, 2003 07:31 AM
Audio28
Dec 27, 2002 01:39 PM
HatchSteer
Nov 22, 2002 06:04 AM
R2D2
Jun 17, 2002 07:40 AM
