DC2 Front Clip
Old Dec 29, 2002 | 05:15 PM
lilman36's Avatar
Default DC2 Front Clip
If i were to purchase a DC2 GSR Front Clip, How much should i expect to get this installed onto my 95 Civic Sedan? Would I need any other parts for this install? What exactly needs to be done? Thanks!
Old Dec 30, 2002 | 01:55 AM
Katman's Avatar
Default Re: DC2 Front Clip (lilman36)
if you bought a complete/untampered JDM OBD1/DC2 clip, everything for the swap would be in it. The only issue would be a an engine harness. You don't wanna use JDM engine harness since the main harness plugs are on the opposite side of the car. I'm not sure what model 95 civic sedan you own, but if its an EX, you can easily reuse your engine harness and just wire up the knock sensor and you'll be set. You can still, reuse your engine harness even if you own an DX/LX sedan, you'll just have to wire up vtec & knock sensors from the ecu all the way out to the engine bay.
[Modified by Katman, 2:57 AM 12/30/2002]
Old Jan 1, 2003 | 12:20 PM
lilman36's Avatar
Default Re: DC2 Front Clip (Katman)
Thanks... My civic is an EX model. Does anyone know how much it would cost to get the clips welded together? Any kind of guesstimate would be appreciated.
dszer89
Aug 25, 2017 06:55 AM
System12Designs
Sep 7, 2011 05:59 PM
gutted
Aug 16, 2010 02:03 PM
Pworld
Mar 26, 2007 03:26 PM
Pworld
Oct 9, 2006 10:29 AM
