at idle car cuts out
Old Dec 29, 2002 | 02:19 PM
drunk's Avatar
Default at idle car cuts out
well i was driving my car friday home from work when it started to do this...let me try to explain this to the point where u can understand...i will be driving my car fine it runs perfec then sometimes when i pull up at a light it just cuts out i start it back up it clunks out after bout 5 times of trying to start it i let it sit for a second it starts back up and runs fine...well i replaced the main relay for the fuel..( i figured it was that because i jumped it and it ran fine so i replaced it). Then today i was driving it stalled out again so i i let it sit and it started back up fine and ran good i nocited that if i keep it at idle above 4000 at a light it was stall i think it is either not getting enough fuel...or getting to much fuel..if anybody has had this problem let me know bout what it could be thanks
Old Dec 29, 2002 | 06:18 PM
b1reed's Avatar
Default Re: at idle car cuts out (drunk)
check your codes, you might want to try a new o2 sensor. that same kinda thing happened to me and a new o2 sensor fixed it. also you might want to check for a leak in the gas tank or lines or perhaps make sure the gas cap is still there, all those things will cuz thats sorta thing also
good luck!
Old Dec 29, 2002 | 10:09 PM
bennyj's Avatar
Try checking your IAC When u come to a stop the throttle plate closes and the IAC gives the moter air when the throttle plate closed like at idle check that then clean the throttle plate with carb cleaner.
Old Dec 29, 2002 | 11:43 PM
88crx Osaka's Avatar
i have same problem with my HF i dont know what could it be also my computer flashes all the time i dont know if is like that on all crx but it flashes all the time.
dc2 teggy1120
Aug 25, 2010 11:42 PM
Mr_ET
Sep 9, 2007 01:35 PM
B_1_8_hatch
Sep 10, 2002 06:44 PM
