ecu pin locations
i did that a while back. use the search!!!
for future reference here it is..
A1 -#1 injector
A3 #2 injector
A5 #3 injector
A7 #4 injector
A8 lock up solenoid (auto only)
A13 ign power #1 for ecu
A15 ign power #2 for ecu
A2 power gnd #1 for ecu
A4 power gnd #2 for ecu
A16 logic gnd #1 for ecu
A18 logic gnd #2 for ecu
A6 Evap purge control valve
A12 fuel pump relay
A14 fuel pump relay
B6 check engine light
B15 ignition control module
B17 ignition control module
A11 IACV (EACV)
C16 Primary O2 sensor
B4 radiator fan control
B10 crank angle pos
B12 crank angle neg
C3 TDC pos
C4 TDC neg
C1 Cyl position pos
C2 cyl position neg
B3 A/C clutch relay
B13 starter swtich signal
B20 service check signal
B1 back up voltage
C10 brake switch
B11 reverse light (HF only)
B14 alternator
B5 alternator control
C6 ECT
B19 ELD
C5 Intake air temp
C9 PA
C7 TPS
B16 VSS
C13 sensor voltage
C12 sensor gnd
C11 MAP
C15 map sensor voltage
C14 Map sensor gnd
A1 -#1 injector
A3 #2 injector
A5 #3 injector
A7 #4 injector
A12 fuel pump relay
A14 fuel pump relay
A11 IACV (EACV)
B10 crank angle pos
B12 crank angle neg
C3 TDC pos
C4 TDC neg
C1 Cyl position pos
C2 cyl position neg
B3 A/C clutch relay
B1 back up voltage
C10 brake switch
B14 alternator
C6 ECT
B19 ELD
C5 Intake air temp
C9 PA
C7 TPS
B16 VSS
C13 sensor voltage
C12 sensor gnd
C11 MAP
C14 Map sensor gnd
md88hfcrx
Dec 12, 2005 11:58 AM
its WANG yoO
Mar 5, 2003 07:16 PM
