Tie rod end question
Old Dec 29, 2002 | 10:53 AM
gray89si's Avatar
Default Tie rod end question
I know that I have my passenger side outer tie rod end out on my rex, but I was wondering if itd be wise to just replace both of them, if they seem to both go out at the same time? Also, would it be recommended to replace the inner tie rod ends with them as well?
Old Dec 29, 2002 | 11:06 AM
jc836's Avatar
Default Re: Tie rod end question (gray89si)
Have you had the car checked by an alignment specialist? What you may have been told is that you need all 4. This really depends on mileage and how sloppy they really are. Personally-I'd change the outer ones, but make sure the inner side is still ok.
Old Dec 30, 2002 | 11:51 AM
gray89si's Avatar
Default Re: Tie rod end question (jc836)
An alignment shop told me that my passenger side outer tie rod is going out, when I had a camber correction kit installed a couple of weeks ago, but I dont think the drivers side is too far from it either. Concerning sloppy handling, its pretty stiff for the most part(I have neuspeed sway bars and strut tower bars all around) but there is a little play which seems to be coming from the drivers side as well....
SVOboy
11
Sep 18, 2005 05:09 PM
eric416
Aug 15, 2005 06:22 PM
yOnKiNaToR
May 17, 2005 11:46 AM
dip-set
Oct 15, 2004 04:26 PM
