h22 question for a accord swap
a buddie of mine told me that you can use an accord tranni for a prelude motor swapped into a 92 accord. ai know thats true but how long will the accord f22 tranni will last on a h22 motor . my friend has a clutchmasters on his and he uses his on pressure plate . can you skate along will that without the tyranni falling out.
cause ive been hearin stuff like the h22 tranni wont fit someone please give me details.
there is absolutely no difference in strength between the two trannys, the difference is the drive ratios and the ring and pinion ratio. An F22 tranny will last the same amount of time as the H22 tranny, but for the extra money i'd rather have the type S LSD for $1000. When i have my F22 tranny in the car at 110 kph or 55 mph im reving like 2000rpm with the H22 tranny its like 3800rpm, so the mileage goes way down.
Exactly. The F22 tranny will not give you the same acceleration characteristics as the H22 tranny would. When I'm cruisin on the highway at 80 mph, my tach is nudgin 4k rpm's! When I had my swap done, I anted up for the LSD tranny. Well worth the added expense in my opinion.
