h22 in a crx....???
have this ever been done? figured it'd be alot of **** to do , converting the cable to hydro clutch, ecu conversion...cutting the tranny mounts and ****???...wondering if any1 ever done it and wat else it takes to make this possible...not like i have enuff money to do it....but jus wanna see wats there to make it happen....thanx
yes it has been done, goodluck man you have o cut the **** out of the frame rails and ****.power to wight ratio IN MY OPINION is way off, and you will drive that setup on the street!
[Modified by H22EK, 12:13 AM 12/29/2002]
very bad idea. i own a 90 hb with an h22 its fast as hell in a staight line but other than that i regret doing it. we did it at my shop like 2 years ago and the car sits now. fast as hell but not fun to drive. if you have the $ to do this swap then just swap a JDM itr into your crx. high 12 sec car right off the bat. we do that swap for 5100.00 installed
ExplicitSpeed
Nov 13, 2004 10:09 PM
