diff btween base and S?
Old Dec 28, 2002 | 08:05 PM
exhaust's Avatar
Default diff btween base and S?
hey guys, i was just wondering what is the mechanical differences between the base rsx and the S model performance wise? like from 160 hp to 200 hp, thanks alot, i really appreciate any response.
Old Dec 29, 2002 | 05:32 AM
ArticBlue03TypeS's Avatar
Default Re: diff btween base and S? (exhaust)
The difference mostly is in the valvetrain. Basically with out getting technical as hell the vtec has a more powerful stage in the s. Both cams engage in vtec opening the valves more to produce more power. I think in the base the the intake cam does most of the vtec work.
Old Dec 29, 2002 | 08:48 PM
exhaust's Avatar
Default Re: diff btween base and S? (eternalbluersx)
thanks for the reply, i really appreciate it, so can is vtec controller change a base rsx to the have the same power as a TypeS, well with some work done to the intake as previously mentioned?
Old Jan 1, 2003 | 05:23 PM
No a vtec controler like the apex vafc will not even with ivtec. The valvetrain itself is just different between the two. When vtec engages the cams a pushed and the lobe on the cam with the longest duration is used to keep the valve open longer to inject a larger air fuel mixture (intake side) and push out the larger amount of combustion faster (exhaust side). On the s model the exhaust side just works better to get more power throughout the RPM range. Sorry about getting so technical
Old Jan 2, 2003 | 09:03 AM
syeve's Avatar
Is the suspension different?
Old Jan 2, 2003 | 12:03 PM
KF_S2000's Avatar
Default Re: diff btween base and S? (syeve)
Yes. Type S gets a firmer ride with more body control.
redINTEGRAdriver
Mar 14, 2005 05:23 AM
racerboyb18c1
Sep 29, 2003 02:54 PM
RTW DC2R
Aug 2, 2002 05:57 PM
Tarmac
Jul 11, 2001 07:22 PM
