Will tranny have impact on dyno#'s
Old Dec 28, 2002 | 05:25 PM
2FASTDC2's Avatar
Default Will tranny have impact on dyno#'s
Will changing from a ls tranny to jdm r tranny change my dyno numbers? Thanks for any help
[Modified by YTRY, 2:26 AM 12/29/2002]
Old Dec 28, 2002 | 05:38 PM
havalilsi's Avatar
Default Re: Will tranny have impact on dyno#'s (YTRY)
as long as you know the gear ratios it doesn't matter
Old Dec 29, 2002 | 01:42 AM
2FASTDC2's Avatar
Default Re: Will tranny have impact on dyno#'s (havalilsi)
bump
Old Dec 30, 2002 | 03:28 PM
PupaScoopa's Avatar
A gearbox with straight-cut gears is more efficent than the usual angle-cut variety found on 99.999 percent of transmissions in the world. This will reduce the drivetrain losses somewhat. The unfortunate thing is that they're very noisy... just like your reverse hear which is straight-cut.
Old Dec 31, 2002 | 04:59 AM
Mista Bone's Avatar
D Tranny Guru
yes it will.
So will tire pressure and front end alignment.
Old Dec 31, 2002 | 05:36 AM
eg6ajk's Avatar
yes it can. higher the FD the higher the torque multiplaction and more power will be seen.
ctr32
Feb 20, 2010 09:09 AM
civicdragger818
44
Aug 6, 2005 06:25 PM
B20T CRX
May 22, 2004 10:51 PM
Dee
Apr 14, 2002 02:55 PM
