Speedometer not working on the 3rd one
Old Dec 28, 2002 | 05:14 PM
Snail Tuning's Avatar
Default Speedometer not working on the 3rd one
ok i have a 91 integra gs with a b16 engine. my speedometer doesn't work when it movies it jumps all over like the spring isn't wotking. my speedo isn't electric its cable driven. ive changed the speedometer 3 times. (3 different ones.) ive also changed the sending unit on the tranny. are the speedometers all bad? when the speedometers are out of the car and u spin the reciver on the back of the speedometer the all jump around. so im assuming the speedomerters are bad.
any help would be apriciated. 2 of the speedometers are from a junk yard.
before i removed the origanal speedometer it would work part of the time but it would be at the corect speed. after o removedit it wold jump all over.
i prolly broke it on removal.
thanks for the help
Old Dec 29, 2002 | 06:28 AM
boosted3g's Avatar
Default Re: Speedometer not working on the 3rd one (bmcc72)
I have a Toyota truck as a beater and the speedo jumps around alittle. Mine jumps because of the bad speedo cable itself. If i turn the radi down and listen closely i can hear the cable ticking. The early 90s integras are notorius for this problem. Take the speedo cable out of the car and pull the wire out. Spray it will lithium grease and you should be good to go.
Old Dec 29, 2002 | 08:24 AM
JALOP B16's Avatar
Ok it sounds like you speedo cable is loose, Its either in the behind the cluster or on the vss check them both. hell pull the out and replug them.
If it dont work replace the cable.
[Modified by JALOP B16, 5:26 PM 12/29/2002]
Old Dec 29, 2002 | 10:44 AM
ok took out the cable an greased it. still jumped around like crazy. tookthe new?used speedo out and rotated the back of it and it jumped around. no resistance on the cable with the speedometer removed. so am i just getting junk speedometers?
help me out i need to fix this before i go turbo.
sir_crx_says
Transmission & Drivetrain
Nov 21, 2013 09:39 PM
G. Man
Classic Hondas
Jul 8, 2011 07:34 AM
PDXHatchback
Mar 2, 2007 10:19 PM
bbrian
Sep 29, 2005 07:30 AM
