obd2 b20 to a second gen teg
im helping out my friend swap a b20 in his 1990 integra. i noticed that they have different sensors on the back of the block.... can somebody tell me on how we approach this problem? i know the teg has a knock sensor, temp sensor, and the other one seeems to be an oil pressure or something... the crv on the other hand have the knock sensor and i dont know the other one... i know for the fact that the temp sensor have to be rewired to connect to the thermostat housing but i dont know if i have to transfer that oil sensor thing or something... any help would be appreciated... thanks
Neither of those motors have a Knock sensor. But aside that it should be relatively easy. The easiest thing to do would be to use the B18A intake manifold and all of the Non-OBD components as well. You should only have to rewire the temp sensor and the rest should all plug in if you use the Integra manifold.
