Make sure you tighten the rotor screw well....
Old Dec 28, 2002 | 03:42 PM
Willard's Avatar
Default Makre sure you tighten the rotor screw well....
...or you will have a issue like this one.
This is a C1 that had been running like that for who knows how long.
Old Dec 28, 2002 | 03:45 PM
Bbasso's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (Willard)
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Old Dec 28, 2002 | 03:46 PM
FSTASNTZ's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (Bbasso)
Wow!! What made them look for that, car not running?
Jason
Old Dec 28, 2002 | 03:50 PM
Willard's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (FSTASNTZ)
I was installing a flywheel and clutch and just happened to look up and saw the underside of the cap.
One of the electrical pins was bent and there were lots of plastic pieces everywhere.
I stuck on a old ITR rotor (more plastic) and a old cap....
"it has never ran better"
Who knows how long it was like that.
Old Dec 28, 2002 | 04:17 PM
Smitdog's Avatar
.............. Wow.
Old Dec 28, 2002 | 04:32 PM
FSTASNTZ's Avatar
Yea, I bet...
Jason
Old Dec 28, 2002 | 04:36 PM
MK Ultra's Avatar
Heh.
Thought you were talking about brakes.
Old Dec 28, 2002 | 05:45 PM
B2FiNiTY's Avatar
Yikes...
Old Dec 28, 2002 | 06:24 PM
Petah's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (B2FiNiTY)
Better run out and check mine now!
Old Dec 28, 2002 | 06:47 PM
brad.'s Avatar
ouchie
Old Dec 28, 2002 | 06:52 PM
Mugen Mike's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (MK Ultra)
Heh.
Me too
Old Dec 28, 2002 | 08:04 PM
Leo's Avatar
Leo
Default Re: Makre sure you tighten the rotor screw well.... (MugenMike)
I was going to change mine tomorrow. This might sound dumb, but how do you get the rotor, so as the screw is facing upward to remove it? I don't want to take the cap off and not be able to get to the screw because it is facing down. Is there anything I SHOULDN'T do? Thanks.
Old Dec 28, 2002 | 08:15 PM
Hooch'n's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (ITR 01-0166)
Good thing you cought it.
Old Dec 28, 2002 | 08:22 PM
naturalvx's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (Hooch at 8400-RPM)
hahahha happened to my roomate, he was calling me scared shitless he blew his motor, told him to check for spark then fuel, didn't take him long to see that his screw backed out and the rotor flew off. I was laughing my *** off, so was he once he realized it wasn't serious.
Old Dec 28, 2002 | 08:35 PM
Rwecked's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (naturalvx)
Happened on my wife's Prelude, checked the R right after that.
Old Dec 28, 2002 | 08:38 PM
SlapSmak's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (Rwecked)
let me tell you from first hand experience how lucky you are. The rotor screw in my R did the same thing, but it bouced around the inside of the cap, cut through the dust shield and got punched right into the middle of the ignitor. end result, 200$ for a new rotor. PIIIIIsssssed off about that one.. that was a mod i could have done.
Old Dec 28, 2002 | 09:48 PM
function83's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (SlapSmak)
yup happened to me destroyed the rotor and the dist.
Old Dec 28, 2002 | 11:26 PM
ej1civic's Avatar
[QUOTE]"it has never ran better"[QUOTE]
he he
[Modified by ej1civic, 8:27 AM 12/29/2002]
Old Dec 29, 2002 | 03:51 PM
Dropspeed's Avatar
Default Re: Makre sure you tighten the rotor screw well.... (ej1civic)
Same thing happened to my ITR a few months after delivery and unmolested by me. I was a Gingerman and thought I had a rod knock, turned out to be arcing inside that cap from the screw bouncing around.......................................Which brings us to Dec 24th (last week) I decided to change the plugs, cap and rotor. Rotor screw was stuck in place, had to take the distributor off, drill out the screw, retap the hole. So much for the qwik tune up.
Mattj
Natural Aspirations
Apr 12, 2008 07:13 AM
littlegreenb18
Jun 24, 2006 10:02 AM
blkgsr03
13
Sep 14, 2005 11:15 AM
Unjockable
20
Feb 15, 2004 03:49 PM
PatrickGSR94
Feb 1, 2003 12:40 PM
