HID: Did you change your fuse?
Old Dec 28, 2002 | 12:51 PM
airon's Avatar
Default HID Q.........Did you change your fuse
So I am in the process of installing my HID's from trevor at visualdynamics (shameless plug for great guy and product) and they work fine
but i have heard various stories to change my fuse to a larger one
should I or shouldnt I?
any hlep is greatly appreciatted!
Old Dec 28, 2002 | 01:07 PM
PauLiE RN's Avatar
Default Re: HID Q.........Did you change your fuse (airon)
change it to 20 amps
your stock fuse will blow after 2 seconds of turning the headlights with the HID headlights installed
Old Dec 28, 2002 | 01:21 PM
-BlueGSR-'s Avatar
Default Re: HID Q.........Did you change your fuse (PauLiE RN)
Ya.. change your fuses...there should be some extra 20 amp fuses in your fuse box....use the ones for the rear power windows if you dont have a four door, they put 20a fuses there even tho we dont have four doors!..i only realized this after i bought spare fuses !!
Old Dec 28, 2002 | 05:51 PM
B2FiNiTY's Avatar
Default Re: HID Q.........Did you change your fuse (GS-ssbp-R)
I use 15A
Old Dec 28, 2002 | 06:06 PM
Buckshot's Avatar
Default Re: HID Q.........Did you change your fuse (B2FiNiTY)
i say change them cuz i turned my headlights on when the car wasnt started and it blew em...so i upgraded
they are only a buck, so what the ****...mine as well get them
Old Dec 28, 2002 | 09:24 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HID Q.........Did you change your fuse (Buckshot)
I went with a 25 y0.
Old Dec 28, 2002 | 09:55 PM
DC2ITR's Avatar
I use 15A
me 2
Old Dec 29, 2002 | 12:37 AM
airon's Avatar
Default Re: HID Q.........Did you change your fuse (DC2ITR)
put in 20a's
just took them from the install bay at work
looks great! gotta clean my headlights now!
thanks for the input guys
Old Dec 29, 2002 | 01:20 AM
TypeR 599's Avatar
does pep boys carry fuses? if not, where can i buy some?
Old Dec 29, 2002 | 01:21 AM
GSRrR's Avatar
Default Re: HID Q.........Did you change your fuse (TypeR 599)
I forgot what I changed it to but I increased it by 5amps.
Old Dec 29, 2002 | 01:45 AM
Mario's Avatar
For those of you who have been recommended to change their fuse; what HID kit are you guys using?
Any retrofit HID kit that cannot work with the car's OEM fuse would give me second thoughts about the quality.
Just my .02 $
Old Dec 29, 2002 | 01:48 AM
GSRrR's Avatar
Default Re: HID Q.........Did you change your fuse (Mario)
well i have the McCulloch kit.
I think most, if not all, of the HID kits require a higher rated fuse because during startup (ignition of the gases) it draws a large amount of current.
Old Dec 29, 2002 | 02:17 AM
01CWITR's Avatar
I use 15A
Old Dec 29, 2002 | 04:46 AM
canuck-mx6's Avatar
Just my .02 $
You sir obviously have never used any hid retrofit kit. The initial current draw is about 9-11 amps, that is why you need to upgrade to a 15 amp fuse
Old Dec 29, 2002 | 06:11 AM
HiRevn's Avatar
Default Re: HID Q.........Did you change your fuse (canuck-mx6)
I put in 20 amps fuses.
[Modified by HiRevn, 10:11 AM 12/29/2002]
Old Dec 29, 2002 | 11:53 AM
tjtruong's Avatar
New User
I use 15A
Old Dec 29, 2002 | 12:21 PM
Mario's Avatar
Wow,
did you not respond to my classified thread about the HID bulbs I am selling off my 9006 retrofit kits?
Good one.
Old Dec 29, 2002 | 01:13 PM
CrazyHondaBoy's Avatar
Default Re: HID Q.........Did you change your fuse (Rguy)
20 amps here. Brian, you're running 25 amp?! Doe it start better than 20 amp?
[Modified by CrazyHondaBoy, 10:13 PM 12/29/2002]
gtowni3
Lighting
11
Apr 26, 2012 05:21 AM
TOTAL-TUNING
43
Feb 17, 2005 07:35 PM
B00STeD
Nov 7, 2002 01:35 PM
TypeR 508
Apr 22, 2002 09:44 AM
GettaluvR
Aug 6, 2001 11:03 PM
