will rear brakes off a 91 crx fit on my hatch?
Old Dec 28, 2002 | 10:31 AM
HatchBox's Avatar
Skoobie no more...
Default will rear brakes off a 91 crx fit on my hatch?
i have searched but found no answer i know that the brake lines will work but will the e brake lines be lone enough?
Old Dec 28, 2002 | 11:07 AM
Jared's Avatar
Default Re: will rear brakes off a 91 crx fit on my hatch? (xxkenyon419xx)
yes
Old Dec 28, 2002 | 11:16 AM
HatchBox's Avatar
Skoobie no more...
Default Re: will rear brakes off a 91 crx fit on my hatch? (Jared)
thanks, also does anyone have the link to the write up of hot to intstall it...
Old Dec 28, 2002 | 11:23 AM
REDBARON's Avatar
Yes it will fit, but the e-brake cables are going to be too short. You're going to need the e-brake cables from a 90-93 Teg.
Old Dec 28, 2002 | 11:38 AM
HatchBox's Avatar
Skoobie no more...
Default Re: will rear brakes off a 91 crx fit on my hatch? (REDBARON)
alright thanks ...so what about that write up page
Old Aug 28, 2006 | 09:09 PM
superhatchbackbros's Avatar
Default Re: will rear brakes off a 91 crx fit on my hatch? (HatchBox)
does anyone have a write up page ? i am trying to do same thing 90-91 crx si rear disk conversion on my 1989 dx hatchback
what brake booster do i need and where do i get a 40/40 valve from what car ?
Old Aug 28, 2006 | 09:45 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: will rear brakes off a 91 crx fit on my hatch? (superhatchbackbros)
Get a 90-93 Integra Non-ABS brake booster and prop valve. (for SiR equivalent, I'm sure CRX install will be the same, I don't think you need to change the MC though)
Links: http://fourthgenhatch.net/reardiscswap.html
http://fourthgenhatch.net/tegmp.html
Good luck!
Old Aug 28, 2006 | 10:09 PM
can anyone help me out
Modified by superhatchbackbros at 9:37 PM 9/3/2006
Old Aug 29, 2006 | 07:32 AM
EL Vap133's Avatar
What front brakes do you have, stock? If you plan on getting bigger front brakes then I would replace both Master Cylinder and Brake Booster.
Old Aug 29, 2006 | 10:58 AM
Default Re: will rear brakes off a 91 crx fit on my hatch? (EL Vap133)
i have stock , i got cross drilled slotted rotors and i wanna keep oem size nothin bigger i just wanna know if i can use just the master cylinder whitch im guessin is the silver part in the (pics) can i just put that in my hatch( take the 2 bolts off and pull it off the black part meanin the booster ) if i get it from the crx si that i got my rear disks from ?
Old Aug 29, 2006 | 12:40 PM
well i just went and got the crx si master cylinder 13/16 that should work with the crx rear disks bc it all came off the same car .......
*** so do i just need to put the stock crx si 90-91 13/16 master cylinder into my stock brake booster on my dx 89 hatchback and hook up the lines to it and then put on the rear disk conversion and hook up all the brake lines and it will work ??? ~ ohh and the E-brake cable from a 90-93 teggie and i should be done ?????
Old Aug 29, 2006 | 12:42 PM
QuarterMileMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will fit, but the e-brake cables are going to be too short. You're going to need the e-brake cables from a 90-93 Teg.
Really? I thought the CRX cables would work...
Old Aug 29, 2006 | 01:01 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros &raquo;</TD></TR><TR><TD CLASS="quote">well i just went and got the crx si master cylinder 13/16 that should work with the crx rear disks bc it all came off the same car .......
Why? You don't need the CRX MC/BB because yours should be the same. Just because you are getting rear discs doesn't mean you need anything bigger than your stock MC/BB.
Old Aug 29, 2006 | 01:31 PM
ohh ok, so then can i use a stock 2040 prop valve or do i deff need to use a 90-93 teg 4040 prop valve ?????
then i should have everything i need to complete my setup right ?
Old Aug 29, 2006 | 04:38 PM
does anyone know if i can just use my stock 2040 valve when puttin on my rear crx si disks or do i have to have the 4040 valve from the teg to make it work.
i was told u can use stock master cylinder (13/16) & brake booster when puttin on the back disk conversion bc it was that way from off the crx ..... but i just wanna make sure about the prop valve so i got the right one to make the job work properly.
Old Aug 29, 2006 | 04:47 PM
Furyof4's Avatar
The stock one will work but may apply too much pressure to the rear brakes, making them lock up easily, not really a good idea. I would definitely upgrade to a 40/40 prop valve.
If you want to upgrade the mc and not the bb, use a 90-91 civic ex or 90-91 prelude 15/16 mc. They bolt up to the stock bb.
Old Aug 29, 2006 | 05:01 PM
Default Re: will rear brakes off a 91 crx fit on my hatch? (Furyof4)
ok ill do it .... will the 4040 valve lines fit the same as the 2040 meaning all i have to do is put my stock civic bracket on the 4040 and everything will match back up perfectly ?
Old Aug 29, 2006 | 05:07 PM
mahatma's Avatar
You won't have to bend any brake lines with the 40/40 DA proportioning valve. I used the DA bracket but I'm sure stock bracket will work fine.
Also no bending of brake lines if you get the 91 Civic EX master cylinder.
Old Aug 29, 2006 | 05:25 PM
jackinthetrunk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a write up page ? i am trying to do same thing 90-91 crx si rear disk conversion on my 1989 dx hatchback
what brake booster do i need and where do i get a 40/40 valve from what car ?</TD></TR></TABLE>
You dont need a write up for something so simple. Only hard part you going to come across with is unbolting the ecable around the gas tank.
Old Aug 29, 2006 | 05:41 PM
Default Re: will rear brakes off a 91 crx fit on my hatch? (jackinthetrunk)
should i take my gas tank down or just unbolt the gas tank clamps a lil to get in there to upbolt the E-brake brackets
on the 90-93 teg is there 2 e-brake cables that i need one for each side left and right ?
Modified by superhatchbackbros at 8:07 PM 8/29/2006
Old Aug 29, 2006 | 08:21 PM
yeah there are 2 cables, one for each side. Like I said, the tank is the only big problem you going to run into. What you do with the tank is unscrew the bolt until it reaches the end of the bolt. That should give you enough comfortable space to take out and put in the cables. Also, get the 40/40 proportional valve and you dont have to do anything to the MC since you leaving the front brakes stock.
Old Aug 30, 2006 | 12:40 PM
Tyson's Avatar
stop calling it a 40/40 ppl.
its 4040. or 2040, 3030, 1725.
40/40 is a nyc club.
Old Aug 30, 2006 | 01:18 PM
ok got it ~ thanks everyone for the help
Old Aug 30, 2006 | 02:05 PM
Boosted Chemist's Avatar
Default Re: will rear brakes off a 91 crx fit on my hatch? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">stop calling it a 40/40 ppl.
lol
Old Aug 30, 2006 | 04:09 PM
40/40 is a nyc club.</TD></TR></TABLE>
I gives a rats **** about anything in NY especially a club.
