Hey Rotary Buzz.
Old Dec 27, 2002 | 04:36 PM
cd555's Avatar
Default Hey Rotary Buzz.
Has your abs leaked at all since you "fixed" the problem? I was thinking about trying the fix but wanted to know if you have had any problems with it.
Old Dec 27, 2002 | 05:25 PM
1genCL's Avatar
Default Re: Hey Rotary Buzz. (farroutt)
you'd probably get a better response if you sent him a PM.
Old Dec 28, 2002 | 02:05 PM
RotaryBzzz's Avatar
Yes, that fixed the problem. However, you MUST torque everything - every essential bolt - to spec. Don't rely on what "just feels right" cause if you don't, you will leak. USE A TORQUE WRENCH. I should actually change my first set of steps to reflect that...
Check the TSB's another guy linked in my thread also. If you have an American-built 95 Accord (or something like that), you have a completely different problem than I do also...you might have a bad seal AS WELL AN improperly torqued together ABS unit. Good luck.
Old Dec 28, 2002 | 02:08 PM
Nick M's Avatar
Default Re: Hey Rotary Buzz. (1genCL)
Trial Users cant PM
Ricorib
Suspension & Brakes
Jun 16, 2013 02:33 PM
obahce
Mar 28, 2007 02:54 PM
TOMSBLUEHONDA23
Nov 10, 2004 07:54 PM
dynamo
May 29, 2004 09:32 PM
vanderoy
Aug 27, 2003 09:36 AM
