Spoon dampers vs Apexi N1 dampers
Old Dec 27, 2002 | 08:49 AM
chameleon's Avatar
Default Spoon dampers vs Apexi N1 dampers
I never seen Spoon coilovers until now, and i couldnt believe it, but i still have not driven on any kind of full coilover dampers, but i know everyone likes the n1 dampers since their all around. does anyone have any experience with spoon's and how it would compare to N1's ?
or are the spoons just full race are they even adjustable ride feel ?
thanks.
Old Dec 27, 2002 | 03:37 PM
chameleon's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (chameleon)
wow ..no aaaaarrr owners around?
Old Dec 27, 2002 | 08:36 PM
AJ PwR's Avatar
Spoon dampers....IMO is one of the best setup for street and track. I have driven them and love them over Apexi. Apexi is too harsh and I don't like bumpy feel (but I used to). If I'm gonna get a Honda again , I definitely will get Spoon coil-overs.
Old Dec 27, 2002 | 09:00 PM
Spikey's Avatar
IMO, there is NO COMPARISON between Spoon coilovers and Apexi N1. Spoon is FAR better. The dampening and smoothness of the Spoon coilovers is unbelievable.
Old Dec 27, 2002 | 09:03 PM
sneakychaos's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (Spikey)
Just curious if you've experienced both sets.
On that note, I haven't... but own a set of Apex N1's. I like them, but they could be a little stiffer on the springs.
Old Dec 27, 2002 | 09:05 PM
Reid's Avatar
Global Moderator
I have to agree with this.
The Apex N1s feel unrefined in comparison.
Old Dec 27, 2002 | 09:12 PM
spoonek4's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (sneakychaos)
I didn't try the SPOON N1 damper kits yet. But I did try APEXi N1 dampers. Umm they're ok. Kinda soft(my friend is running below 10K in front, and that's a EK SiR sedan)....I'm agreed with what Spikey said. I think APEXi N1 is only at the ZEAL B6/TEIN RA's level.
I did try the SPOON street damper kit with Kg/mm DR21 springs both street and auto-x. All I can say is amazing. I like them sooooo much.
Old Dec 27, 2002 | 09:17 PM
Spikey's Avatar
yep
we're very lucky in Vancouver @ A&J. get to try so many things
Old Dec 27, 2002 | 10:21 PM
chameleon's Avatar
keep em coming guys, this is a great help!
Old Dec 28, 2002 | 12:03 AM
ill phil's Avatar
Just curious- but not all of the Spoon Dampers are height adjustable are they? I didn't know if all of them are, so if someone could enlighten me on the different levels available, I really don't know much about these.....
chameleon- just mentioning this because I remember in the last thread you had discussed wanting to drop your car enough to eliminate gap, and liked the Apex'i N1's due to being able to adjust height without sacrificing stroke of the damper.
Old Dec 28, 2002 | 12:31 AM
chameleon's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (ill phil)
i have a chance to get some spoon dampers, and apexi dampers, just that the spoons are more rare, and wanted to make sure i make a right descision to not pass them up. oh yeah and im a sp00n wh0re anyways.. the ones im looking at are definitely ride height adjustable and i think are ride feel as well ..
i dont want to pass em up since their rare as hell to me.
Old Dec 28, 2002 | 02:48 AM
spoonek4's Avatar
The SPOON N1 dampers are pretty short stroked. So even your leave it up high it's still pretty damn low.
For ride quality u really won't regret.
Old Dec 28, 2002 | 02:54 AM
Reid's Avatar
Global Moderator
Don't you need Spoon parts to be a Spoon *****? JFWY
Get the Apex N1s or something similar (a coilover that can adjust ride height independent of preload), since you want to slam your car to the ground.
Honestly though, GC's and some Konis would be fine for your purposes and cost a lot less also.
Old Dec 28, 2002 | 02:58 AM
spoonek4's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (Reid)
How often do u track your car anyway?
Old Dec 28, 2002 | 04:50 AM
SUPERAUTOBACS's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (spoonek4)
To add: Assuming that u track/autox the car, do u use street or race compound tires?
Old Dec 28, 2002 | 06:09 AM
chameleon's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (SUPERAUTOBACS)
i dont auto-x yet, but i plan to and try new things, so im looking for suspension that can do it all. right now i have season tires since its snows here and all that. come spring then i can switch to better tires and take advantage of the susp further.
Old Dec 28, 2002 | 06:12 AM
chameleon's Avatar
Yes i know, should have more stuff on by spring, like sp00n calipers
um ..i never said i want to slam my car to the ground ..what gives you that idea?
what are my purposes? and i already know this.
Old Dec 28, 2002 | 06:18 AM
RagingAngel's Avatar
I might be one of the few who has had both sets on my car at one point in time.
what I like about the Apex-i.
Their aluminum construction and their full range of adjustability.....
from dampening to stroke.
I find that they ride very well with their "stock" spring rates if you set them up properly. Zero preload and leave their dampening level at 1.
I like their little features that matter on the street like dust boots, and that they do a great job all around. I haven't tried them with higher rates, but I suspect they won't do as well as the Showas I've had.
What I like about the Showas:
They ride awesome even with the 16/14 rates that I had briefly on the street. Their no nonsense dampening settings ....5 way instead of the Apex-i which are like what? 16? or something?
I spoke to Ichishima-San about setting them up for the street and he addressed my worries about the low ride height.
I don't like how they ride low because of their super short stroke...but I know how to fix that now. I also don't like the fact they don't come with dustboots....but you can't have everything now can you?
on lower rates.. 10/8...they ride like butter.... still the absolute best that I have tried to date over the ZEAL B6 that I had before too, not to mention the other dampers I have had on my car.
I plan to get another set again....
Old Dec 28, 2002 | 08:05 AM
Petah's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (RagingAngel)
How did you manage to fix the low ride height? I am planning to purchase a used ITR off my friend that has a set on his car already. Initially, i installed the spoon/showas for him and even at max ride height, they sit damn low!!!
But let me vouch for the Spoon/Showa, they ride so smooth. I have driven on the Spoon/Showa and Apexi N1 before. The spoon is far superior in performance compared to the Apexi N1. The spoons are stiffer at full stiff and softer and full soft when compared to the N1s. But the only down fall with the Spoon is the cheap construction. The N1 are made from aluminum and the ride height is adjusted via lengthening and shortening the shock body.
Old Dec 28, 2002 | 03:01 PM
chameleon's Avatar
Default Re: Spoon dampers vs Apexi N1 dampers (eg-six)
hey you two .. how would zeal b6's compare to spoon's or the N1s?
Old Dec 28, 2002 | 03:09 PM
Won't ride as well as the Showas.
I know MiraiZ or other people from JDM land might say differently but I feel our North American asses are more prone to broken pavement than what I saw and experienced when I was riding around in Japan....
But they offer a lot of value over the Showas in terms of FEATURES....
stroke adjustable, solid top hat mount with bushing, 6way adjustable.....etc..etc...and my personal fave..dustboots...haha
Old Dec 28, 2002 | 03:25 PM
chameleon's Avatar
but their definitely on top of N1's ..like u said
i need to get my priorities straight. so i know what to go for and is no way i can get that then go down the list
gwakie
Apr 29, 2007 10:59 PM
Spids5
Suspension & Brakes
Mar 5, 2006 08:50 PM
hammerdgolfer
Sep 3, 2004 12:34 AM
spoonJDMteg
Jul 17, 2003 09:54 AM
