AEM fpr question...
Old Dec 26, 2002 | 11:38 PM
HondaCutter's Avatar
Default AEM fpr question...
with stock fpr and walboro 255 hp, I'm at about 60 psi at idle. I did the fuel pressure mod found at "theoldone.com". I want to know if I get the AEM fpr, will I be able to drop the fuel pressure down to 40 psi? or will I still have to drill a whole?
Old Dec 27, 2002 | 02:23 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: AEM fpr question... (HondaCutter)
I'm pretty sure the AEM FPR comes with different bypass plates.
Hondata suggests either the drill method, or AEM FPR.
From AEM's website.........
Our patented interchangeable discharge ports enable the regulator's output to match the output of ANY fuel pump.
Old Dec 27, 2002 | 05:26 AM
Desslok's Avatar
Default Re: AEM fpr question... (Mista Bone)
My AEM came with 3 different ports. The FPR lets you adjust the fuel pressure down, I think to 20 PSI. THose discharge ports are so when you have high pressure, and you are at WOT and let off the gas, it doesn't go into an overly rich condition and cause a rough idle until the pressure stabilizes.
turbochic
May 15, 2003 06:29 PM
dochmees
Nov 21, 2002 12:16 PM
snake01
May 31, 2002 12:54 PM
Rodney
Apr 2, 2002 08:07 AM
