ignition timing, idle, octane.
Old Dec 26, 2002 | 03:11 PM
p0pe's Avatar
Default ignition timing, idle, octane.
Help me diagnose a problem please, my car has been idling kind of rough and seems like its lost some power. I recently switched to 91 octane for a couple of tanks and it helped, it idles a little smoother and seems to have more power and run smoother in general, then switched back to 87 and it seems to run like crap again. My car also idles a little fast, around 800 rpms or so, but in my helms it says check ignition timing, clean throttle body, etc. first. EDIT: gas mileage w/ 91 octane was better (25 mpg city) than w/ 87 (around 20-22 mpg).
Could the ignition timing be causing this or should I look elsewhere first? I've recently changes plugs, acl, and had a valve adjustment. I'm about to change the plug wires. Thanks
[Modified by p0pe, 6:15 PM 12/26/2002]
Old Dec 26, 2002 | 04:19 PM
KingDsi's Avatar
Default Re: ignition timing, idle, octane. (p0pe)
What car are we reffering to? What year and how many miles?
You changed plugs and soon wires, what about a new dist cap? How about a new fuel filter? Age + injectors + fuel filter + bad dist spark = rough idle and bad gas mileage.
Old Dec 26, 2002 | 07:48 PM
pennies_hatchie's Avatar
Default Re: ignition timing, idle, octane. (KingDsi)
is there a swap involve or just the oem engine and what car is it
Old Dec 27, 2002 | 04:32 AM
p0pe's Avatar
Default Re: ignition timing, idle, octane. (pennies_hatchie)
sorry, its for my 97 accord ex, 72k miles on it, no swap.
[Modified by p0pe, 7:32 AM 12/27/2002]
Old Dec 27, 2002 | 05:15 AM
1bad-eg's Avatar
Do the wires and then adjust your base idle, and then your timing advance. You should good to go after that.
Old Dec 27, 2002 | 05:22 AM
Desslok's Avatar
Default Re: ignition timing, idle, octane. (1bad-eg)
If it's idling a little fast, and runs better on higher octane, sounds like the timing is too far advanced.
nonsense
22
Sep 27, 2004 07:45 AM
mr_mbuna
Nov 28, 2002 11:12 AM
roydogg
Aug 20, 2002 06:21 PM
