Are 88 front shocks different from 89-91?
Old Dec 26, 2002 | 01:13 PM
Civic44's Avatar
Default Are 88 front shocks different from 89-91?
I know the rear suspension is different between 88 and 89-91 Civics, but now I notice that the front shocks Bilstein sells are 89-91 and the Tokico seem to have different model numbers for 88 and 89-91. Can anyone clear me up on this? Are 88 and 89-91 front shocks interchangeable?
Old Dec 26, 2002 | 01:37 PM
andrew dc's Avatar
Default Re: Are 88 front shocks different from 89-91? (Civic44)
the 88 rears are different... fronts are all the same
Old Dec 26, 2002 | 01:41 PM
SIRX's Avatar
Default Re: Are 88 front shocks different from 89-91? (CRX25)
Old Dec 27, 2002 | 07:57 AM
REDBARON's Avatar
Default Re: Are 88 front shocks different from 89-91? (SIRX)
There is a difference in the 88 shocks. The brake lines mount differently. Other than that, they are the same.
Old Dec 27, 2002 | 09:57 AM
CRX-RX's Avatar
Default Re: Are 88 front shocks different from 89-91? (REDBARON)
Ya, I have a set of 88's on th front of my 90 hatch and had to break off the front mounting tab. Other than that, same height, size, everything else.
Old Dec 27, 2002 | 10:03 AM
Team 4's Avatar
Default Re: Are 88 front shocks different from 89-91? (CRX-RX)
88 rear incorporates passive rear steering, with ITR style eye mounts for the shocks. Never lower an 88 too much, as it induces snap oversteer.
Old Dec 27, 2002 | 12:22 PM
gray89si's Avatar
The fronts should work fine, I sold a set of 91 CRX Si front struts to a friend of mine on his 88 CRX HF and there werent any fitment issues
Old Dec 27, 2002 | 08:55 PM
Rincon's Avatar
Default Re: Are 88 front shocks different from 89-91? (REVHARD_EF)
What would be considered to low? I was planning on lowering my 88 EF (koni yellows/skunk2) about 1.5 inches so I want to be sure that will not be too low.
Old Dec 28, 2002 | 02:54 PM
Civic44's Avatar
Default Re: Are 88 front shocks different from 89-91? (Rincon)
My 88 is lowered 1.75 inches (I think, H&R race) and there is no snap oversteer, the car is very neutral.
Old Dec 28, 2002 | 03:04 PM
Team 4's Avatar
I had initial setup issues with the car. If you have a good (stiff) rear brace and a stiff sway bar, it will rotate. Keep it above 2" and it should be fine. The EF rotates better than my EG as well, which is great for throttle steering.
Old Dec 30, 2002 | 09:21 AM
wadafa's Avatar
i'm lowered with h&r race w/2" in back and am still understeering, so don't worry bout that too much
Skipper75
Apr 16, 2007 06:48 AM
DarkSol97
Dec 3, 2006 08:44 PM
JH4DC231
Oct 12, 2005 06:12 AM
The DX Rex
Nov 22, 2004 12:14 PM
Full-Race Henry
Oct 28, 2003 10:41 PM
