3 Stage VTEC D15B(Y5?)
Doesn't the three stage version of the JDM D15B have two solenoids? I'm happy with my D15B. It's pretty quick. You can also get them at http://www.ardperformance.com. They also sell SOHC ZC VTECs.
There's no such thing as a "staged" VTEC. VTEC is either OFF or ON, there is no stage 1, 2, 3 thing, whatever your talking about.
All VTEC does is engage a larger set of cam lobes, and if Honda wanted to do this on any engine, they're have done it on the DOHC VTEC, to allow different VTEC engagement points on the intake/exhaust cams strictly for performance.
Also, no SOHC VTEC ever had VTEC on anything but the intake lobes. Honda never touched the exhaust sides.
All that means is that the engine runs in 12 vavle mode until 3k the first solenoid activates, and it runs at 16 valve mode. After 6k, the second solenoid activates and the wild cam is engaged.
I think you are refering to the VTEC-E motor. It's a super economy motor found in the later HX models. It's not a performance motor.
VTEC-E - Variable valve Timing and lift Electronic Control for Efficiency. This system isn't really VTEC as we know it. At low RPM, the VTEC-E mechanism effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At a set RPM value (i.e., ~2500RPM in the D16Y5), the VTEC-E mechanism engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. Note: in a VTEC-E engine, there are no high-RPM performance cam profiles; this engine is supposed to be tuned for fuel economy, right?
Cool thing about this motor is that it has roller rockers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid »</TD></TR><TR><TD CLASS="quote">There's no such thing as a "staged" VTEC. VTEC is either OFF or ON, there is no stage 1, 2, 3 thing, whatever your talking about.
Also, no SOHC VTEC ever had VTEC on anything but the intake lobes. Honda never touched the exhaust sides.</TD></TR></TABLE> =>Your'e a moron!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue_Si03 »</TD></TR><TR><TD CLASS="quote">All that means is that the engine runs in 12 vavle mode until 3k the first solenoid activates, and it runs at 16 valve mode. After 6k, the second solenoid activates and the wild cam is engaged.</TD></TR></TABLE> =>
Sorry if I had to bring this up. I have a 3 stage vtec on my 2001 vti. Heres a pic to prove it.
Notice the two actuators on top of the IM. And notice that it doesn't have a distributor. My car is an A/T and it runs 15 to 20 Km/L in the city.
It runs 12-valve mode, then when it reaches 2,500rpm it runs 16 valve mode. Then @ 5000 rpm the wild cam profile engages.
Good day!
Good day!
well the vti does not exist to America, so there is a valid reason as for why he wouldn't have known.
Just like anyone who says Hondas don't come stock w/ turbos don't know what they are talking about, cause here in europe there are stock Turbo hondas.
We can't fault them for not knowing about the EU, AUS, or JDM Market completely, as they don't have the same easy access to it liek we do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid »</TD></TR><TR><TD CLASS="quote">That engine code doesn't look like a d15y, does it, bitch?</TD></TR></TABLE>
Its a 1.6L and this is in the Philippines. I do not know the JDM equivalent of this motor, d16 something I guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 »</TD></TR><TR><TD CLASS="quote">well the vti does not exist to America, so there is a valid reason as for why he wouldn't have known.
We can't fault them for not knowing about the EU, AUS, or JDM Market completely, as they don't have the same easy access to it liek we do</TD></TR></TABLE>
Well, sorry if I was offensive on that post. Its just the way he spoke as if he knew everything about vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emong3 »</TD></TR><TR><TD CLASS="quote"> =>Your'e a moron!</TD></TR></TABLE>
I really wouldn't call someone with a 300hp b16a a moron.
We don't have that engine here in the states nor would it be one that we'd really want anyways. Also seems honda is really dumbed down the VTI's in the years. At least the VTI CRX had a b16a.
He was primarily asking about three stage vtec...which there is such a thing available, btw. He asked if it was a y5...not stated such. Now play nice, especially when you're wrong.
Quoted from TOV http://asia.vtec.net/article/d15b/:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">For the EK-generation Civics, development on the D15B engine finally culminated in the now famous 3-stage VTEC D15B. This engine is used on the current generation EK3 VTi and Ferio Vi. 3-Stage VTEC D15B is a wonder engine in that Honda took the technologies of the VTEC-E and VTEC-D15B engines and merged them into one single engine. This implementation, already covered elsewhere in TOVA, allowed Honda to give us an engine that is both economical and powerful. So, who says we can't have our cake and eat it too?</TD></TR></TABLE>
Well, sorry if I was offensive on that post. Its just the way he spoke as if he knew everything about vtec. </TD></TR></TABLE>
I know everything I need to know aobut a performance motor... I don't care to know everything about the econo-motors because they aren't an enthusuast interest.
We can't fault them for not knowing about the EU, AUS, or JDM Market completely, as they don't have the same easy access to it liek we do</TD></TR></TABLE> there are stock honda turbo's i want more info on that, the only stock turbo honda in the states is a jet ski. there only like 1.2 liters but they put out 165 hp
There is a stock Turbo Accord and a Turbo Civic over here in EU. Only problem is they are diesel.
go to http://www.honda.de look for the CTDI Civc or Accord..... More info is there
I know everything I need to know aobut a performance motor... I don't care to know everything about the econo-motors because they aren't an enthusuast interest.</TD></TR></TABLE>
did you even read the article ranta18 posted???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kshymkiw83 »</TD></TR><TR><TD CLASS="quote">There is a stock Turbo Accord and a Turbo Civic over here in EU. Only problem is they are diesel.</TD></TR></TABLE>
so whats the horsepower in those cars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton »</TD></TR><TR><TD CLASS="quote">
right because it automatically makes you a genius
