Shorter h22 gear ?
Old Dec 26, 2002 | 11:07 AM
Mighty Mintos's Avatar
Default Shorter h22 gear ?
is there anyone in so. cal that can custom shorter gears for an h22 tranny? i have an f20b and at the end of the quarter mile i'm still in 3rd gear. these gaers are way too long. Help me please.
Old Dec 26, 2002 | 11:44 AM
2point6's Avatar
Default Re: Shorter h22 gear ? (F20bcivic)
What do you rev to?
Old Dec 26, 2002 | 11:54 AM
satan_srv's Avatar
https://honda-tech.com/zerothread?id=310639
Euro-R accord or Accord Type-R H22a trannies are the best for acceleration:
Euro-R/Type-R Tranny:
1st: 3.285 61km/h (7400rpm => 4708rpm) [64km/h (7800rpm => 4963rpm)]
2nd 2.090 96km/h (7400rpm => 5244rpm) [101km/h (7800rpm => 5527rpm)]
3rd 1.481 135km/h (7400rpm => 5351rpm) [142km/h (7800rpm => 5640rpm)]
4th 1.071 187km/h (7400rpm => 5610rpm) [197km/h (7800rpm => 5913rpm)]
5th 0.812 246km/h [259km/h]
Final 4.266
4th gen is also good with a shorter first gear
M2B4 = LSD
M2F4 = Non LSD
Final Drive: 4.266
I : 3.307
II: 1.950
III: 1.360
IV: 1.034
V: 0.787
Rev: 3.00
5th gen
1st - 3.285
2nd - 1.956
3rd - 1.344
4th - 1.034
5th - .787
rev. 3.
Final 4.266
Old Dec 26, 2002 | 08:33 PM
Default Re: Shorter h22 gear ? (2point6)
i make power to 8500 and i shift at 8850.
Old Dec 26, 2002 | 08:43 PM
satan_srv's Avatar
That's what I like to hear boss..I'm building my motor with an F20B crank, do you have a dyno graph? List of mods?
Old Dec 26, 2002 | 08:58 PM
Default Re: Shorter h22 gear ? (satan_srv)
well all i have is JUN cams, i/h/e, HONDATA stage 2a and tuning. i make almost 210hp to the wheel. and about the dyno, ill try to scan it and post it.
Old Dec 27, 2002 | 12:03 AM
DsITR's Avatar
M2B4 = LSD
M2F4 = Non LSD
Final Drive: 4.266
I : 3.307
II: 1.950
III: 1.360
IV: 1.034
V: 0.787
Rev: 3.00
5th gen
1st - 3.285
2nd - 1.956
3rd - 1.344
4th - 1.034
5th - .787
rev. 3.
Final 4.266
satan...according to that the 5th gen has a shorter 2nd and 3rd gear?
Old Dec 27, 2002 | 07:41 AM
aklucsarits's Avatar
New User
Both Pro Drive ( http://www.prodriveusa.com ) and Houseman Autosport ( http://www.housemanautosport.com ) will make you a custom H22A final drive gear to your specs.
Andrew
Old Dec 27, 2002 | 08:06 AM
satan_srv's Avatar
Thank you thank you. In the meantime where are your peak HP and Peak torque What times are you running so far?
[Modified by satan_srv, 12:09 PM 12/27/2002]
Old Dec 27, 2002 | 08:08 AM
satan_srv's Avatar
Default Re: Shorter h22 gear ? (dsludefosho)
No the higher the number, the shorter the gear. The 5th gen has a slightly shorter 2nd gear than the 4th gen, but barely...
Old Dec 27, 2002 | 03:00 PM
satan_srv's Avatar
I founf some ratios for some accord F series trannies that would probably work...i mean you're trying to select gears that maximizes the powerband of your graph right?
Old Dec 27, 2002 | 03:42 PM
se93's Avatar
Joel:
Let me know as welll on those F series gear ratios.
Old Dec 27, 2002 | 04:13 PM
satan_srv's Avatar
Default Re: Shorter h22 gear ? (se93)
https://honda-tech.com/zerothread?id=273763&page=2
Like I wouldn't mind the 5th gear from the S model hehe...
http://www.honda.co.jp/factbook/auto.../ac93-023.html
The F18, F20 and F22 JDM motors all have a 1.483 2nd gear for their auto trannies. I don't know anything about trannies, but I'll guess that you could use this as a 3rd gear, even though its auto?
Correct me if I'm wrong...
Old Dec 28, 2002 | 12:02 PM
are those really the gear ratios for the euro-R tranny?
Old Dec 28, 2002 | 02:00 PM
satan_srv's Avatar
Yes they are, Accord Type-R as well.
Could you tell me the rpms you make peak hp and peak tq in the F20b? Or e-mail your dyno graph to jbycraft.hba2002@ivey.ca thanks.
Old Dec 29, 2002 | 06:43 PM
flyrod's Avatar
The M2F4 is the 4g prelude VTEC tranny. Are you sure on the 5th gear ratios between the M2F4 and the 5g manual tranny? I thought the 5g had a taller 5th gear. Can someone with a 5g manual post what rpm their engine is at in 5th gear on the highway going like 60 or 70 mph? I've been trying to find out if a taller 5th gear can be swapped into a M2F4 tranny for cruising on the highway with the engine at a lower rpm. I know the 5th gear from a 4g Prelude S will not fit. I think the S tranny is the same as the accord trannies, so that won't work either. Has anyone successfully done this????
Old Dec 29, 2002 | 10:35 PM
1fast5gp's Avatar
Default Re: Shorter h22 gear ? (flyrod)
spoon final drive set.. those are bad ***..
2001GSRSC
Sep 26, 2017 12:28 PM
v8h8
Apr 23, 2009 02:42 PM
ExplicitSpeed360
Feb 25, 2006 11:49 AM
lazy bum shaughn
Oct 22, 2002 09:04 PM
