f22b dohc water pump
i need to know from anyone who has knowledge of the f22b twin cam engine, which parts are interchangeable between the motor and us parts. for example the timing belt is the same timing belt for a gs-r or type r, alternator is an accord or a prelude unit, and the power steering unit too what is the usdm counter part. i want to change my timing belt but i want to change the water pump out as well, along with the seals(how many seals are there 1 or 2). any help is apreciated. or if anybody knows of a shop that has worked with this motor previously thanks
[Modified by f22btwincam, 11:35 PM 12/25/2002]
You got the Timing Belt and **** right...
Water pump is also GSR or i believe LS....
Right now i'm also building a F22B but still dunno if i'm gonna boost it or just go all motor
yesterday i just change my water pump for my cb4 import model from japan. my old water pump likely from usdm cause theres was a eagle logo on it. and have change it using the f22b B8 prelude water pump from japan aisin senki co. ltd. for your info i'm using a f20a dohc. and it's perfectly fit to my accord.
freezerman
Aug 30, 2007 03:30 AM
J.nguyen
Jul 14, 2005 01:00 PM
