Driver Side Interior Panel ( 91 accord )
Old Dec 25, 2002 | 06:33 PM
RUBZERK's Avatar
Default Driver Side Interior Panel ( 91 accord )
I need to know if anybody can tell me how to remove my driver side door panel.
i need to get it off so i can put my window back on track. i have power windows & door locks
Old Dec 25, 2002 | 08:52 PM
StimpyBoy's Avatar
Default Re: Driver Side Interior Panel (RUBZERK)
I probably can give it a shot. I did that recently to retrieve a lock cylinder that fell inside *grrrrrrr*
On the inside door latch, pry off the screw cover and unscrew the one or two screws there. Pry the latch trim back, you'll see a small metal rod connected to the latch via a plastic clip piece. Remove the clip piece from the latch. I broke the piece doing this and had to get a new one from Canadian Tire, feh.
With that off, there was another silver screw holding a bracket to the door, remove that screw. Then, there are two or 3 screw covers on the trim (one you have to open the door for, one in the map/garbage rests thing). Remove them.
You now have to pry off the plastic clips all around the door trim. There are like 2 on the front and back, and like 91873982374 on the bottom (more like 7). I used a long screwdriver to pry them off by leveraging in the general area of each, but you could probably even use your hands.
Then, just lift the trim up and off. There's plastic all around the door, peel back the plastic and use a razor to separate it from the adhesive.
I've left out one part, the window control mechanism. That's because my car has no power windows, and my repair manual is in the car. I'm sure someone can fill in that one missing part, or you can just figure it out.
[Modified by StimpyBoy, 6:07 AM 12/26/2002]
CXHatchback
Mar 7, 2020 09:21 PM
bopbop93030
May 14, 2008 12:45 PM
XViEtBoiX
Honda Civic (2001 - 2005)
Dec 16, 2006 10:38 AM
cavr6
Audio / Security / Video
Jun 17, 2006 01:40 PM
dlgray
Mar 13, 2006 09:35 AM
