Is a clutch from honda alright for racing?
Old Dec 25, 2002 | 02:25 PM
BseriesHatch's Avatar
Default Is a clutch from honda alright for racing?
I had a stock clutch put in when i put my ZC in a couple months ago. It grabbed pretty good for the first few months but then started to slip. What do you guys think about honda clutches?
Old Dec 25, 2002 | 02:33 PM
spettinger's Avatar
Default Re: Is a clutch from honda alright for racing? (Novtech)
honda clutches are great for a minimal pressure, grocery getter. they last a long time under those circumstances. i am still running the stock clutch on my B16, i plan on getting an exedy sometime.
Old Dec 25, 2002 | 04:30 PM
Rob!'s Avatar
Default Re: Is a clutch from honda alright for racing? (2ndhandCRX)
i would like to get a nice aftermarket clutch for my b16 soon as well
Old Dec 25, 2002 | 05:14 PM
b16_madman's Avatar
Default Re: Is a clutch from honda alright for racing? (RaceFacer)
i am keeping the stock clutch also(on my b16)...how long and how much abuse
have yall given yours???...the dx honda clutch lasted 12 years when my aunt drove it....they last
[Modified by B16_madman, 2:15 AM 12/26/2002]
Old Dec 25, 2002 | 05:45 PM
Hondasaurs's Avatar
I can compare my stock clutch to a monkey trying to climb a greased pole. Thats how bad it would slip every time I got on it. I replaced it with a Centerfore Dual-Friction clutch. This clutch grips great, but I get a lot of wheel hop now.
Old Dec 25, 2002 | 06:00 PM
spettinger's Avatar
Default Re: Is a clutch from honda alright for racing? (ZC_CRX)
my stock clutch on my B16 would definitely chirp third, then i ditched the 13" steelies in favor of 15" C-8's, they would slip a little into third, not as noticeable as before. then i put in some stock del sol vtec cams, and it would chirp into third, but only with another person in the car. i think the added would have more inertia, as in the car wanted to stay where it was during a shift, rather than continuing to accelerate. ( i have never taken a physics class yet, so i will apologize to those that can see through my B/S explanations.) haha
stock clutch works ok, just want a damn exedy already! or an ACT street/strip setup.
Old Dec 25, 2002 | 06:30 PM
Jared's Avatar
If you want a stock clutch, get the Clutchmasters Stage 0. It's their stock replacement, OE quality grabs great and is less than a Honda kit.
Old Dec 25, 2002 | 09:28 PM
habib_88's Avatar
I heard you can bolt in a stock clutch from like a 92+ civic and its a little bigger and better (must use 92+ flywheel i think, maybe someone can back me up on this). But right now i'm saving for a centerforce dual friction, so thats what i'd recommend.
[Modified by habib_88, 10:28 PM 12/25/2002]
Old Dec 25, 2002 | 09:44 PM
slowcarguy's Avatar
Default Re: Is a clutch from honda alright for racing? (habib_88)
I just scammed a 94 EX clutch from work and put it in my 89 si...(with a 90/91 flywheel...same as a 5th gen) and yes, it is a hair bigger. I had been slipping on a stock crx clutch with 40K on it and wanted to give it a try. NO BETTER....I run 9 psi on my y8 and it slips whenever I get on it. I have a heavy duty pressure plate and the hybrid street disc coming to me in the mail....I hope that'll soolve my problem.
Old Dec 25, 2002 | 09:45 PM
CimorelliCRX's Avatar
92+ flywheel is the same as 89+. we ised a 95 on my freinds crx..
Old Dec 26, 2002 | 03:33 AM
REX VT's Avatar
Default Re: Is a clutch from honda alright for racing? (CimorelliCRX)
Stock B16 clutch plate and DC2 pressure plate (125% over stock) = combo
Old Dec 26, 2002 | 07:46 AM
Driven's Avatar
Default Re: Is a clutch from honda alright for racing? (REX VT)
Autozone type clutch/pressure plate.
No problems, only minor slips when it's cold.
I have run it for a year now... uber-autocrosses/road races.
Old Dec 31, 2002 | 02:23 PM
So a 92+ clutch would work for a 90 si?
Old Dec 31, 2002 | 02:29 PM
89civicdx's Avatar
a 89 civ/crx flywheel is not the same as a 90+ only a 89 civ/rex clutch will work with a 89 flywheel. The 89's use a hub with bushings and the 90+ has a sprung hub.
[Modified by 89civicdx, 3:40 PM 12/31/2002]
Old Dec 31, 2002 | 02:32 PM
slowman's Avatar
I took way too long
Default Re: Is a clutch from honda alright for racing? (slowcarguy)
my stock honda clutch has 77,000 miles on it and it still chirps 2nd and not a sign of slipping.
Old Dec 31, 2002 | 05:21 PM
Malgerus's Avatar
Default Re: Is a clutch from honda alright for racing? (slowmanEF)
My brother roasted his stock B16A clutch... I'm not even going to bother getting one for my B16A. ACT all the way!
Old Jan 1, 2003 | 12:08 AM
B20zvtecek's Avatar
Default Re: Is a clutch from honda alright for racing? (CRXSiBeater)
Just installed an ACT heavy duty plate with 6 puck disk into my lsvtec. chatters like a ****, pedel effort is very very hard, but grabs like a ****
Old Jan 1, 2003 | 06:30 AM
johnzm's Avatar
Default Re: Is a clutch from honda alright for racing? (B20zvtecek)
action segmented kevlar i loooooovvve it and stage1 PP so its easy to drive on
Old Jan 1, 2003 | 06:44 AM
USDM 4G VTEC's Avatar
cant recall right now.. and cant find it on my papers.... but i beleive the honda stock clutches hold 750-950 PSI range....
under continuous streess honda clutches are not very friendly.. the springs that disipate the torque tend to get loose and give u a non adecuate grip..
i would stick to a CM stage 2 clutch.. they hold about 1500 psi and they are great for punishement... droove it and thats what ill be getting with tax money...
Old Jan 1, 2003 | 11:03 AM
1RMDave's Avatar
well when i did my b16 swap i could squeal 2nd and chirp 3rd after time it was only chirping 2nd. put in my act 6 puck with extreme presure plate i has small squeal in 3rd and chirps in 4th...i also had very shitty tires.
Old Jan 1, 2003 | 11:22 AM
Kamin's Avatar
Default Re: Is a clutch from honda alright for racing? (johnzm)
hell yea i have the action 6puck and it KICKS ***
Old Jan 1, 2003 | 12:27 PM
Jeef's Avatar
back to the sizing... the 90-91 has a little more surface area than the 88-89, when my clutch was swapped they swapped in a light weight flywheel for a 90-91 in my 89 and got the bigger clutch... and it works really well... heh with my 13's on i could break loose going into 3rd, or i could hook up in first go to about 5 grand driving normal punch it and break em loose... now that was fun heh
T_ypEr
11
Sep 23, 2011 01:52 PM
k20z3fan
Honda Civic (2006 - 2015)
15
Jun 22, 2009 04:10 PM
TypeR324
Honda S2000
Oct 8, 2008 09:52 AM
Alchemist
Nov 21, 2005 05:05 PM
