Rotor Screws-Where to buy?-Help yO
Old Dec 24, 2002 | 08:34 PM
Ef Whore's Avatar
Default Rotor Screws-Where to buy?-Help yO
I just took off my powercrap rotors tonight ,since santa is bringing brembo blanks, completely destroying the 2 screws.---Where can I get these exact replacement screws or is that a dealership part? thanks and Merry Christmas.
Old Dec 25, 2002 | 01:10 AM
88_SC_CRX_Si's Avatar
New User
Default Re: Rotor Screws-Where to buy?-Help yO (Ef *****)
What I have seen/read from other posts, that they are really not needed. They were used to hold the disc on during production. However, might just line the holes up, just in case there is any indexing tho..
Old Dec 25, 2002 | 05:24 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
just go to a hardware store (lowes, home depot...etc) and get a similar screw that wont stick out from the rotor. i cant remember what size it is though 6 or 8 mm? just make sure you use antiseize so you can get the damn things back out again!
Old Dec 25, 2002 | 08:35 AM
Ef Whore's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (fastcrxsi90)
thanx but cant I just get the ones that belong there from honda?
Old Dec 25, 2002 | 12:34 PM
the DR.'s Avatar
yes you can
Old Dec 25, 2002 | 04:21 PM
FitCRX's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (CIVICtypeS)
just forget them..they are just to hold the disc on while installing...if you can't find them..don't worry about it.
Old Dec 25, 2002 | 04:30 PM
EG8R's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (FitCRX)
Use one on each side.... Ni biggie like they were saying....
Old Dec 25, 2002 | 07:29 PM
ThatRicerDaniel's Avatar
PICK AND PULL ~ !!! any civic should work. and there free if you got deep pockets
Old Dec 25, 2002 | 08:21 PM
Aphrodavid's Avatar
when i replaced with brembo blanks, i had to drill out those screws, i just left them out, havent had a problem
Old Dec 25, 2002 | 09:00 PM
carsaregood's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (DX-R)
i once found them at a local parts store... that was a few years ago though.. they were in the red packages made by Motormite or Help! or something like that.
Old Dec 25, 2002 | 09:01 PM
Ef Whore's Avatar
the blanks are in, i made a christmas illegal junkyard run, ganked the screws(somehow these came right out with WD-40) and I will bed these badboys in in the a.m.
Old Dec 25, 2002 | 09:41 PM
big pete's Avatar
what screws
Old Dec 25, 2002 | 10:21 PM
Ef Whore's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (big pete)
I just dont get why u guys leave em' out, i mean its just that much more holding in place and u never know they could shift....
Old Dec 25, 2002 | 10:54 PM
big pete's Avatar
youre wheel studs and calipers hold them in place
Old Dec 26, 2002 | 07:24 AM
keithv's Avatar
you are kidding right? 4 lug nuts torqued to 80 ft-lbs each will be more enough to hold the rotors on.
all those screws are for is making your next rotor change that much harder.
Old Dec 26, 2002 | 07:39 AM
crxgurlllll's Avatar
youve obviously never had to take out a rusted rotor screw
Old Dec 26, 2002 | 07:42 AM
EP3_05's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (eraser)
No kidding...When I changed rotors about 4 years ago I had to drill those screws out. What a pain. So I installed new ones with antisieze compound and the last time I changed them they came out very easily.
Old Dec 26, 2002 | 08:42 AM
zCivic's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (91civic)
Drilled them out and left the rest of the stud in the hub. Thats what I did. What can I say I'm lazy
Old Dec 26, 2002 | 11:28 AM
Ef Whore's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (zCivic)
mine came out, took a while, but I put them back in because they belong there.
Old Dec 26, 2002 | 12:30 PM
racerxadam's Avatar
they belong there so when the car passes over your head on the assembly line the rotors don't fall off and kill you
Old Dec 27, 2002 | 12:22 PM
rioninja's Avatar
i bought a few new ones a couple years back, cost me less than $1.50 for all. And contrary to what most of you may think, you do need them. There is about a mm of side to side play without them in place. True that isnt a whole lot, and wont be enough to throw anything noticably out of balance, but i'd rather pay a dollar than worry about wheel bearings down the road.
Old Dec 28, 2002 | 11:14 AM
Ef Whore's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (RioNinja)
I knew there was some other reason than to hold them on during assembly---honda put them there for a reason.
Old Dec 28, 2002 | 11:28 AM
REX VT's Avatar
You don't need them, rotor rusts stuck to the hub soon enough
Old Dec 29, 2002 | 07:22 AM
crx_91si's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (REX VT)
if you guyz want to take the screws out the right way, next time try one of these
Impact drivers work wonders
& no, the screws are not necessary to put back on. But if you dont want to sit there stripping screw drivers or screws, and then having to drill them shitz out, buy one of these and make your life easier.
Give it a fat wack with the hammer and the screws spin right out
Old Dec 29, 2002 | 05:46 PM
Ef Whore's Avatar
Default Re: Rotor Screws-Where to buy?-Help yO (FourthGenHatch)
how much do those bad boys retail for? Does home depot have them?....i dont know where to get tools around here.
