Oil pan is dented
Old Dec 24, 2002 | 10:16 AM
cr-x si's Avatar
Default Oil pan is dented
My oil pan on my zc has a huge dent in the bottom of it. I am just curious if this would affect the enigine when i install it? I am planning on using my a6 oil pan for the zc i was just wondering if a dented oil pan will mess anything up.
Old Dec 24, 2002 | 10:20 AM
Malgerus's Avatar
Default Re: Oil pan is dented (cr-x si)
Yes, depending on the dent. If it's really bad you could have oil supply problems. i know on the VTEC engines that dents can sometimes affect VTEC (due to lack of oil pressure). But then again, My brother's B16 has dents in the oil pan. If it's not too bad you should be ok. Good luck. Why not post pictures?
Old Dec 24, 2002 | 10:28 AM
cr-x si's Avatar
Default Re: Oil pan is dented (Mr. S)
no digital camara or scanner
Old Dec 24, 2002 | 10:43 AM
Vinceg99's Avatar
Well if you have it off you could try denting it back out?? I dont know where the dent is and if its accesable but its worth a shot??
sb98ctr
Oct 18, 2008 05:50 AM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
Andrewm224
Jul 16, 2005 08:08 PM
