Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
koni shox
Old Dec 23, 2002 | 06:45 PM
Leb_CRX's Avatar
Default koni shox
well here's the story...
3 month ago I ordered some koni yellos from a store...they had the front ones so I payed for those right away, than they ordered the rear (took them 3 month) anyways 3 motnh later I get a call and I go in and they got me the front ones too (by accident instead of the rear)...ok no problem so I got a refund instead of having to wait another 3 month and went to another shop that I knew had some in stock and picked up the rear ones
anyways I bough the rear ones for my civic and now I noticed and it dawned on me that the rear is the neuspeed edition and the fronts are the sport ones...
is this gonna matter? I DONT plan on moving the perches around, they are sittin on co's so I can adjust ride height that way...
anyone know if that will matter at all?
Thanks
|eb_CRX
[Modified by Leb_CRX, 7:47 PM 12/23/2002]
Old Dec 23, 2002 | 09:55 PM
krshultz's Avatar
Default Re: koni shox (Leb_CRX)
No idea. I'd call Koni *and* Neuspeed directly and see what the differences are.
Old Dec 24, 2002 | 01:10 AM
DB2-R81's Avatar
25 Year Member
Default Re: koni shox (krshultz)
The Neuspeed dampers should be valved for marginally higher rate springs and the body should be slightly shorter then Sports. Will it cause a problem, no.
Old Dec 25, 2002 | 12:13 PM
MattG's Avatar
New User
I am no expert but I would think as long as each damper matches front to front and rear to rear you should be fine.
Old Dec 26, 2002 | 12:02 PM
isotopesope's Avatar
Default Re: koni shox (DB1-R81)
they're 20mm shorter and have five perch settings rather than three, but i'm not sure about the higher spring rate capability.
Old Dec 26, 2002 | 12:15 PM
DB2-R81's Avatar
25 Year Member
Default Re: koni shox (isotopesope)
Neuspeed "Race" springs for most Honda's/Acura's are in the range of 500lbs so I assume they should be valved to dampen these spring rates which OTS Sport Koni's can only just handle. Best bet is to check with Neuspeed.
[Modified by DB1-R81, 1:16 PM 12/26/2002]
jit01
Suspension & Brakes
Apr 17, 2007 01:39 PM
onramp
Feb 19, 2004 08:32 PM
integranator
Jan 4, 2003 07:18 PM
sjteg
Dec 27, 2002 10:07 PM
Razor
May 7, 2002 08:11 PM
