Internal Engine Casting Flash
Old Dec 23, 2002 | 05:50 PM
Bullet50's Avatar
Default Internal Engine Casting Flash
Is there any benefit to removing internal engine casting flash while I've got yhe engine torn down?
I'm building a B20 for boost (new rods, pistons, rings, cams,etc.) I've removed all the external cast flash and am sending it for a dip in the acid tank before the rebuild and paint. Thanks in advance for any feedback.
B50
Old Dec 24, 2002 | 12:06 AM
kinesistech's Avatar
Default Re: Internal Engine Casting Flash (Bullet50)
Its not necessary, in fact why would you dip it in acid? I think you would do more harm than good. Especially if your going to paint it afterward. That just holds heat better.
Old Dec 24, 2002 | 02:43 AM
Mista Bone's Avatar
D Tranny Guru
removes possible stress risers and allows oil to flow better back to the pan.
Old Dec 24, 2002 | 03:08 AM
Bullet50's Avatar
Default Re: Internal Engine Casting Flash (kinesistech)
It's purely cosmetic.............. I started out removing the flash to make the engine cleaner. Like the saying goes "Paint can only cover so much. The better the base the better the final product." The reasoning behind the acid dip is to save all the degreasing work required before paint. The dip won't hurt the engine. All the internals are out. Once it comes out of the tank it looks brand new.
B50
vyrus
Apr 9, 2013 03:11 AM
b20beast83
Paint and Body
May 15, 2009 06:01 PM
MNsnowdaboy
Paint and Body
Jan 20, 2008 08:21 PM
kay_animation
May 21, 2002 11:07 AM
