Is it bad to start the car in 2nd grear?
Old Dec 23, 2002 | 01:59 PM
slowassR's Avatar
Default Is it bad to start the car in 2nd grear?
1st great has a bit of go to it. Is it bad to start of in second. I never do but I see some of my buddys with faster cars using 2nd grear at stop lights ect.
Old Dec 23, 2002 | 02:02 PM
Chris N's Avatar
Default Re: Is it bad to start the car in 2nd grear? (slowassR)
I use 2nd from a 5mph roll, or sometimes when it is slick/snowy outside so that I can get traction without as much trouble.
What's bad about it? You just won't have much power at all <2.5K rpms. If you aren't going from a slow 5-10 mph roll (like in heavy traffic) or in the snow, what's the point?
Old Dec 23, 2002 | 02:04 PM
yoshi234's Avatar
I shoot brides
w/ the 4.9, i just leave the car in 2nd when stuck in traffic. It's almost like an automatic tranny
Old Dec 23, 2002 | 02:12 PM
Black R's Avatar
25 Year Member
Default Re: Is it bad to start the car in 2nd grear? (yoshi234)
.....ditto.
Old Dec 23, 2002 | 02:18 PM
Chris N's Avatar
Default Re: Is it bad to start the car in 2nd grear? (Black R)
:sigh: 4.4 owns me.
Old Dec 23, 2002 | 02:24 PM
davidnyc's Avatar
you may have to slip the clutch more... so, yes if you do it all the time it would be bad. But once in awhile, no problem. If you wanted to you can get the car rolling in 5th gear, just have to slip the clutch ALOT.
Old Dec 23, 2002 | 02:25 PM
rainmanEK's Avatar
big strong guy
Default Re: Is it bad to start the car in 2nd grear? (Chris N)
****... I start off in third!
4.7 fd, Toda FW, and 2200lbs Owns Me!
eric
Old Dec 23, 2002 | 02:32 PM
Bbasso's Avatar
If you slipp the clutch, your burning it. Try not to start in anything higher then 1st.
other wise your not really hurting anything.
Old Dec 23, 2002 | 03:10 PM
Teepo's Avatar
Default Re: Is it bad to start the car in 2nd grear? (Bbasso)
starting in higher gear puts more stress on the crank and most likely can wear bearings...2nd gear is ok sometimes, you just have to be good with the clutch
Old Dec 23, 2002 | 03:37 PM
Hooch'n's Avatar
Default Re: Is it bad to start the car in 2nd grear? (ITR1150)
agree
Old Dec 23, 2002 | 05:30 PM
paRRRker's Avatar
Default Re: Is it bad to start the car in 2nd grear? (Hooch at 8400-RPM)
Old Dec 23, 2002 | 06:07 PM
J_Edwards's Avatar
Default Re: Is it bad to start the car in 2nd grear? (Hype-aaaRRRR)
I start in second all the time. If you aren't trying to get anywhere fast it isn't a big deal. I can start in second the same way I do in first, just takes longer is all.
Old Dec 23, 2002 | 06:15 PM
1GreyTeg's Avatar
.....ditto.
ditto+1
Old Dec 23, 2002 | 06:30 PM
4-1-1's Avatar
damn straight y0 G
Old Dec 23, 2002 | 07:12 PM
vtec.dc2's Avatar
yes it is, and it gets worse with agressive cams.
Old Dec 23, 2002 | 07:14 PM
B2FiNiTY's Avatar
Default Re: Is it bad to start the car in 2nd grear? (vtec.dc2)
My dad does it all the time. We will see how long his car lasts.
Old Dec 23, 2002 | 08:17 PM
machgo5go's Avatar
Default Re: Is it bad to start the car in 2nd grear? (B2FiNiTY)
My dad does the same thing, annoys the hell out of me. Its one of those Old style lasy *** thinking that u don't jerk your body so much with a smoother action. I wish match rev is one of the lessons in drivers ed so u know how to roll smoother in first gear.
Old Dec 23, 2002 | 11:37 PM
TypeR 599's Avatar
Default Re: Is it bad to start the car in 2nd grear? (machgo5go)
i usually have it in 2nd while i put along a parking lot looking for a spot. i'm usually too lazy to stick it back into first when i stop. so i just hold the rev at 800 until it starts move in second
Old Dec 24, 2002 | 12:38 AM
SoCal ITR's Avatar
Default Re: Is it bad to start the car in 2nd grear? (TypeR 599)
I don't do it, because it will wear out the clutch faster.
Old Dec 24, 2002 | 04:45 AM
canuck-mx6's Avatar
Can't wait to get my tranny with the 5.0 Cusco FD.
r01516
Sep 10, 2008 12:04 PM
evo8psi23
May 24, 2008 11:07 AM
racingcrx
15
May 31, 2006 05:16 AM
h22HatchEG
Mar 12, 2006 03:20 PM
GoLowDrew
Aug 21, 2001 10:38 PM
