Occasional low rpm stumble..... :(
ok, need the boards' help on this one, bout two weeks ago did some maintenance, plugs, oil change, fuel filter change....nothing out of the ordinary, used OEM filter, bosch platinums (model # per h-t recommendation from someone, forget who). now, every so often, when starting from a stop at a light or something, the motor stumbles. only low rpms, sub 2000, then runs fine after that. pulls like it should in VTEC, no other issues, CELs or anything. anyone have any suggestions? perhaps i used to the wrong plugs or something, could that be it? any help would be appreciated....
rob
rob
get rid of those Bosch Platinums ..and get some OEM spec NGK's ....sorry if i'm racist ...but
German Plugs with German Cars
Japanese Plugs with Japanese Cars
i put some Bosch in my G1 along time ago...car starting missing about two months later ..ended up the plugs were fouled
even though they came pregapped ..i still checked the gap ..so they were within spec ...
but the plugs still failed
EJ8_Enthusiast
Oct 8, 2008 07:33 PM
